-   -   Clicking noise (http://forums.pelicanparts.com/porsche-911-technical-forum/345187-clicking-noise.html)
qlander 05-06-2007 07:35 PM
Clicking noise
I had a great drive today from central Jersey to Brooklyn, NY.
All went well except for a faint clicking noise emanating from the driver's side rear wheel.
Only heard when close to a barrier that makes the sound bounce back. No grinding or vibrations. Sounds like wheel bearings.
Is this normal or am I looking at replacement soon?
Thanks,
Q.
jbrand540 05-06-2007 08:07 PM
If its centralized to one side of the car it is probably loose valves. When were the valves adjusted last?
qlander 05-06-2007 08:21 PM
A long time. I've had the car 2 years now and haven't done it. No problem with acceleration or pinging. It sounds like a possible culprit though.
Thanks,
Q.
jbrand540 05-06-2007 08:38 PM
If its been 2 years then the valves should be adjusted. Its the first thing that I would check.
I adjust mine using the backside method outlined in the Pelican Tech articles. After 2 times of doing it I can adjust them in about 3-4 hours including the hour + it takes me to get everything out and back in just to reach the valves.
bigchillcar 05-06-2007 09:01 PM
sounds like cv's or wheel bearings.
jbrand540 05-06-2007 09:04 PM
I was assuming this was with car stationary next to wall is this while in motion?
rcecale 05-06-2007 09:15 PM
+1
Randy
qlander 05-07-2007 05:03 AM
Yes, the noise is while in motion.
Q.
911mot 05-07-2007 05:04 AM
A stone stuck in the tyre tread
jmcn3rd 05-07-2007 06:49 AM
I had something like this once on my 72 targa. It turned out it was the e-brake cable rubbing on the back of the wheel. The mount broke so I had to use some wire to hold it in place. Possible?
Miguel Antonett 05-07-2007 11:40 AM
Worn sway bar bushing...
goober 05-07-2007 12:58 PM
My 84 Carrera track car is doing the same thing. Is not related to engine speed. (if I push in the clutch at speed the clicking frequency does not change) Mine is definitely coming from the driver side rear also.
a-dougk1 05-07-2007 03:12 PM
Before doing anything expensive, check your tires for stones in the tread or some metallic object embedded in the tire. I've had the same symptoms numerous times and it has always been either a stone in the tread or a nail with its head still intact. Even with a nail embedded in the tire, you may not loose any air (at least for a while, so check it soon).
Doug
DaddyGlenn 05-07-2007 03:27 PM
Important question - Does the speed of the clicking change in relation to wheel speed or engine speed?
