frankc's Avatar
Where to find NLA brake lines?
I'm looking for just two more OEM brake lines to finish the line replacement on my 77S. The lines I need are the front right and rear left hard lines. I believe all the hard lines are NLA now, but I've managed to order the others through the local dealer and they did arrive after about 6 weeks!
Here are the numbers I'm looking for:
911 355 617 01
911 355 627 00
Any suggestions would be greatly appreciated.
Frank
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 05-06-2007, 09:26 PM
Gon fix it with me hammer
svandamme's Avatar
there are kits out there, that allow you to make your own lines from copper, come with a tool to make the endings on whatever lenght you want
Stijn Vandamme
BIMDIESELBMW116D2019
Old 05-07-2007, 12:22 AM
David's Avatar
As good or better than OEM: http://www.fedhillusa.com/
Old 05-07-2007, 03:05 AM
I good trick is to use either a coat hanger or thick wire to figure out the right route and bend angles. Now you have a template to put mandrel bends in straight brake line and can cut to the proper length.
Old 05-07-2007, 05:08 PM
