one more wire to connect
THANKS TO EVERYONE ON THE FORUM, MY CARRERA IS RUNNING.
Just one more little problem.
I got all the aftermarket alarm stuff out and removed the factory alarm stuff.
The car runs by turning on the key to on position, I then close the contacts on the DME relay (cover is taken off) with a small plastic clamp. This is the relay furthest from the 6 metallic prongs. Then, I turn the key to start , it starts and runs great.
What isnt connected, what do I do now. If I remove the clamp from the relay while it is running , the car shuts off, If I leave the clamp off and turn the motor off with the key, it restarts, but the clamp is still on the furthest relay from the prongs.
I must need to place a wire from the dme relay to a fuse that is hot in the on position and start position---right? Which one?
Cant thank everyone for the pointers, all the info led me to getting it running.
david
Old 05-11-2007, 12:12 PM
