H1 or H4 - which are these?
could someone help me out? I assumed these were H4 lamps because thats what the lenses are. what are they? thanks, Don.
2 bulbs means H1
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
thanks randywebb!
Get some H-1 lenses to enjoy the true output. The fresnel design is specific to each light...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
yep...they are right
2 bulbs = H1 if you have 55 watt bulbs....plug and play if you have the flamethrower 110 watt bulbs.....you'll need relays, or prepare for a meltdown in wiring, switches, etc great lights nonetheless
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS |
Mine says H4 right on the glass.
'03 Boxster ***** '82 911SC **** '98 BMW Z3 ** '87 300Z *** '80 BMW 320i **** |
H4's also have two bulbs. City light.
Carl, |
Carl could have nailed it...pulling the bulbs would tell, H-1 and H-4 bulbs are vastly different in shape...
city light should be way on the bottom - not in the converging axis of the reflector bowl
but won't hurt to look at the bulbs & yes get the right lenses, add good bulbs & relays, then fire away...
