-   -   Front turn signal light function question (http://forums.pelicanparts.com/porsche-911-technical-forum/345967-front-turn-signal-light-function-question.html)
spiff 05-11-2007 05:20 AM
Hi Folks,
I have a quick question. I've updated my '80 SC with C2 bumpers and lights. Do the front turn signals have a built in parking light function on the normal SC's and Carerra's or is it purely a turn signal light that is only on/off (no parking light "dim" function when lights are on)?
I'm assuming that the signals purely flash on/off and the parking light function is a separate connector/light.
Can you confirm?
Thanks in advance.
fred cook 05-11-2007 06:15 AM
Front turn signals........
The front turn signals on the SC have a dual filament bulb. One is the parking light, the other the turn signal. That way you can have the parking lights on and have a turn signal function at the same time. If you are using the C2 lights in your conversion I would think they would work the same way. Just remove the lens and look at the bulb.
Hope this helps.
