brake pads on 911t
I've got a 73.5911t that I need to replace the brake pads on. The car will be mostly street driven, but that will include a few trips to the mountains, and perhaps down the road a little track fun time.
What specific pads would you recommend for a car like mine? I also need to replace the rotors, and wondered if drilled rotors would provide much improvement or are they mostly for show? Thanks, Ashford
'70 Triumph TR6 '73.5 911T |
Drilled rotors are mostly for show, there's lots of threads about cracked drilled rotors. Our host sells Ferodo pads that are a nice street pad.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
+1 on the drilled for show. Stick with a stock rotor. Everyone has their favorite pad, so you are likely to get wide range. From what our host says, the Ferodo or Metal master would be a good small step up over the OEM.
John Snodgrass 1973 Porsche 911 "Barney" (race car for sale) 2008 Nissan Maxima - Daily Driver 1999 F350 Diesel Crew Cab - Tow Beast 1990 Airstream 36' Land Yacht - Home Away From Home |
Way back when, I had very good luck w/ Repco Metal masters for street use. The same pads are currently available under the PBR and Axxis brand names. You still won't be sorry if using them for that purpose.
Thanks for the responses. How are the Ferodo pads about giving off dust?
