Porsche 911 engine pulling out
Hi i am pulling out my engine to change the main crank seal, and i am looking for suggestions what else can be done to the engine while it is out, considering it runs good.
Thank you I do appreciated German |
Gon fix it with me hammer
all sorts of things that can be done...
valve adjust, hydraulic chain upgrade, tranny seals, motor mounts, check for broken headstuds, change oil return tubes how much budget do you have? if you do a search for "while the engine is out" you'll find plenty of ways to break the bank, and then some then there are the specifics for certain types of 911 engine.. what do you have??
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
You didn't say which enging you're working on. If it's an SC, then I'd change the oil pressure warning light sensor, thermostat o ring, and crankcase breather gasket. All cheap parts.
Then I'd have a beer, and put the engine back in. |
Thank you guys,
this is a 1974 2.7 not an sc I firstly want to do the cheap up grades and considering ill go from there |
Senior Member
Buy a new engine firewall pad if yours is not in perfect condition. They are a bear to replace with the engine in the car and are not too expensive.
Spend a few bucks and steam clean the engine compartment and detail it while the engine is out.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
The reason I mentioned SC is that the oil thermostat et al are impossible to replace with the engine in the car. Basically you do stuff like the engine sound pad that Joe mentioned that are impossible to do with the engine still in.
I wouldn't create additional work though, just stuff that you know you have to do later when the engine is out. |
19 years and 17k posts...
Rear shock replacement, replace heater hoses, all vacuum hoses and flexible fuel lines, clamps, etc... are cheap and easy with the engine out.
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
You can replace the seal without dropping the engine. Support the HE's, lower the engine and remove the engine mount and cross brace. This would give you good access to the area of concern.
1985.5 944 GTS |
definetly will change the pad and lots more suggested things, i will drop the engine anyways, want to learnhow to do it, and my mechanic is my friend we are doing together
thank you guys |
I have a 2.7 also. My upper oil pressure sending unit was leaking. so I dropped the engine. I did the oil breather and thermostat gaskets while I was there. The sending unit is a $6.95 part and should be changed if you have the engine out.
I did a valve adjust while it was out, it makes it so easy. New spark plugs too. I had already installed carrera tensioners when I did the rebuild, but if you don't have them it's a top priority upgrade.
PorschePilot 74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration MID9 Member Beechcraft V-Tail Bonanza (Fly'n high and low) |
