1980 911 SC fuel pump
My 911s fuel pump that was sitting for last 20 years is dead. Is there anybody that knows the difference between 1980 fuel pump and later that are cheaper? Looks like the BOSCH for later models is much cheaper.
_______________________
Thomas
2004 Carrera 4S - daily driver
1980 Carrera SC ROW - sold - gave up on the project
Old 06-04-2014, 05:41 PM
The pressure changes with the Carrera pumps, they won't work forCIS
80 to 83 are external check valves, the 77 to 79 have different fittings on the fuel lines and internal check valves.
the 80 to 83 is the only correct pumps
Bruce
Old 06-04-2014, 07:15 PM
FP replacement.........
Do you know the part # on your FP? There are so many Bosch FP's that would work for your '80 SC namely: 0-580-254-984/985/053. I've been using -984 and quite happy with it. Others have used non-Bosch FP like Walbro and heard good feedback with it too. What you need is a high pressure FP (90 - 100 psi.) , a flow rate of 2 liters per minute (minimum) , and comparable size. Preferable replacement FP is Bosch 0-580-254-series but other brands would work too.
Tony
Old 06-04-2014, 07:56 PM
I got one of this ebay "Porsche BMW VW AUDI Universal" 5 Bar.
Flow 228l / h in spare till mine breakdown ?
Dont know any part# but hope it fits when needed.
911 SC -83 Coupe
Old 06-05-2014, 04:52 AM
I found here Bosch Part #: 911-608-102-02-M14 for $254.50
and i also found Bosch Part #: 69513 for $ 129.97
I am not trying to be cheap but they look the same, they are both Bosch and it says it is for Porsche 911.
Thomas
Old 06-05-2014, 05:43 AM
grateful user
don gilbert's Avatar
Look up THe Fuel Pump King in Cali,,,bought several bosche pumps for 150.00 over the yrs,,,no fails yet. Have your old pump #.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 06-05-2014, 06:10 AM
old pump number is 0 580 254 053
I found more details and the Bosch Part #: 69513 and it seams to be same as OEM Part Number 0 580 254 984
it also looks like the original pump specs are:
175 l/h (2.9 l/min) 5 bar (72.52 PSI) 11.5 A
and the specs for 0 580 254 984 are:
165 l/h ( 2.75 l/min) 5 bar (72.52 PSI) 10 A
Thomas
Old 06-05-2014, 06:24 AM
Picture of FP-053........
Thomas,
Could you post a picture of your old FP? Forgot how the -053 looks like. Thanks.
Tony
Old 06-05-2014, 06:46 AM
Will do - later tonight - it is still mounted to the car
Thomas
Old 06-05-2014, 08:11 AM
porwolf's Avatar
There are many Bosh fuel pumps. But most important are the pressure and pumping capacities. All other part numbers refer to the input and output connections. I understand that Bosch fuel pumps are interchangeable between cars of different makers as long as the pump specifications are identical. Walbro pumps have the same specifications and are also interchangeable but they have a reputation of being less reliable. But at their price you can afford to carry a spare.
Here is a short list of Bosch fuel pump specifications.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 06-05-2014, 11:59 AM
i bought a fuel pump $29.00 w/ free shipping on ebay for my 83sc. been running good for a couple of years now
Old 06-05-2014, 12:29 PM
Had to work late but managed to make two pics.
Thomas
Old 06-06-2014, 05:42 AM
OK, never mind the pump the fuel tank is totally corroded! I searched all threads and the only reasonably solution is to buy a new one.
- new tank
- new fuel lines
- and yes almost forgot ;-) new fuel pump
Thanks for all help!
Thomas
Old 06-12-2014, 05:18 AM
Less brakes, more gas!
euro911sc's Avatar
Search can be your pal
Fuel Pump
This fellow is just like you... just a few years earlier
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 06-12-2014, 10:53 AM
