78 911 Sc
I am a possible new Porsche 911 SC owner, I've found a 78 that is very clean Motor supposedly rebuilt 9K ago and its a 130K car. Black on Black with 944 8 Way seats and a clean interior.
It has 930 Sterring wheel 911 Whale Tail 4.5 B&B stainless Ehaust Carerra Tensioners Poppoff Vale and valve covers Comes withe cover and a bentley manual The gears grind ever so slightly from 1st to 2nd the car runs very well and is very tight. Beautiful interior engine hardly smokes at start up does backfire slightly does leak a little oil. Is it worth 9K? Thanks, Paul |
Not until you get a PPI.
Jon |
Reasonably what should I pay for a pre purchase inspection?
Former Options Trader !!!
You have to get a PPI .. plus the paper work for the rebuild. Sounds like the syncros are shot in the tranny too. Forget the "clean" motor its not all that hard to make it look pretty.
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster |
I am waiting for Zimms Porsche to call me back about a PPI
You are getting a leakdown, compression test, and checking studs, right? $9k sounds too cheap for that car (with the rebuild) so I'd be suspicious.
Even with the tranny issue, which simply may be the fact that you're not used to shifting a 915 transmission, 9k is a very good price for the car if it checks out. Dash, interior ok? Been wrecked?
Warren Hall (Early S Man), 1950 - 2008 ------------------------------------ 2006 Tri D675 Scorched Yellow 2006 Ducati Sport Classic mono SOLD 1979 SCWDP #0020 Talbot Yellow SOLD |
