heavyer weight oil... less oil pressure?!!!
Hey guys,
I recently switched from 10w40 shell to 15w40 rotella shell. I also switched to a genuine porsche oil filter from a german aftermarket brand ( forget which one)
Anyway, now at idle, the oil pressure guage bounces around the 1 mark! is used to be about the 2 mark, is this normal? during reg driving, it is always above 3, mostly at the top part of 4
thanks!
Andrew
1985 3.2 black carrera coupe
Andrew Deihl
adeihl@gmail.com
Old 05-16-2007, 04:53 AM
Slumlord
Porsche_monkey's Avatar
I believe normal would be 1 bar/1,000 rpm.
So, 1 bar at idle is fine, 3 bar at 3,000 rpm would be good.
A 10W40 and a 15W40 should be exactly the same viscosity when warm, i.e. 40. I wouldn't expect to see any significant pressure differences with those two oils.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 05-16-2007, 05:35 AM
