goober's Avatar
911 turbo sways on a 77 911S?
Will stock sways off of a mid-eighties 911 Turbo (the rear sway bar measures 20mm, the front sway bar measures 22mm) fit a 1977 911S?
The rear has the "G-50 bend in it". The sways are currently fitted on a stock 1984 Carrera.
Old 05-14-2007, 07:22 PM
They'll fit. The front will just bolt up with new, larger bushings. In the rear you'll need to get creative with the drop links as the 77 style is a ball-and-cup, while the 78 and later is a bolt on to the trailing arm. I modified my 74 drop links to work, but you can purchase aftermarket (Tarret) links that bolt to the spring plates.
Old 05-14-2007, 08:33 PM
Jon,
I'd like to put Carrera sway bars on my SC. Is there a difference between pre-G50 Carrera bars and G50 bars? Any difference in how they will mount on my SC?
Thanks.
"Life is good"
Old 05-16-2007, 07:52 AM
On an SC it's a straight bolt up in both front and rear, but you will need all new sway bar bushings. The thicker bars that you want were on Carreras from 86-89. The 86 is the only non-G50 year for these bars and the only difference is an extra bend in the middle of the bar to clear the larger transmission.
Old 05-16-2007, 10:27 AM
Jon,
Thanks.
"Life is good"
Old 05-16-2007, 12:14 PM
