door stop
something is totally corroded and the door creaks like mad while opening and closing the door. im guessing its the infamous door stop that is finally giving way. i can actually seeing it moving inside the actual door. how much do those babys run?
Old 12-13-2006, 04:02 PM
KNS KNS is offline
The new stop with the re-enforcement kit is around $60.00. It only gets worse over time and it is a DIY unless some welding is required.
Kurt
Old 12-13-2006, 04:07 PM
Paul Ferradas's Avatar
Do these doors actually have stop points? Mine seem to open all the way if you let them go. Kind of a hassle when your parked close to a car and you have to hold the door from swinging open.
Old 12-13-2006, 05:04 PM
I just had my driver's side door check replaced by a body shop. There is a noticeable difference. It stops at about 1/4 open, just enough to slip in, then again at about 3/4 open. I purchased a kit for the passenger side and will be doing that one myself.
Old 12-13-2006, 05:21 PM
Door Stopper....
85Carrera,
If you just need one door stopper, I got an extra one. This is new and never installed for $25. Send reply to atd911@hotmail.com.
Thanks.
Tony
Old 12-13-2006, 07:39 PM
dazed and confused
john baldwin's Avatar
Door stop kit
Crosby50,
What part did the body shop use?
What kit did you get?...Pelican's door stay kit (911-531-957-00-M260) or the reinforcement kit (PEL-PP911167) or both?
Both my doors swing wide!
89 Carrera 3.2 Targa
2011 BMW 335d
2013 BMW X3 3.5
80 911 SC Weissach Coupe (Sold)
Old 03-10-2007, 09:07 AM
I'm not certain what the body shop ordered. On the other door, I ordered Pelican's door stay kit. I don't think you need the reinforcement kit unless your door's sheetmetal has been compromised by repeated over-swings.
Old 03-10-2007, 11:19 AM
durn for'ner
livi's Avatar
My driverīs door has flied open since I bought it 2 1/2 years ago. Pretty annoying. The remedy seems out of my DIY league though, so I suppose Iīll live with it. Carefully holding the damn door every time I open it..
Markus
Resident Fluffer
Carrera '85
Old 03-10-2007, 11:33 AM
when i got my car the driver side stay was ripped clean out of the sheetmatal. i just bent the metal back to where it resembled original and used very big washers on it. it works great
Old 03-10-2007, 01:26 PM
billroth's Avatar
Wink
Very easy repair. I, a newbie, did it with minimal damage
Lawrence
1985 911 Coupe Black
1985 911 Cab GP White (killed)
Old 03-10-2007, 01:43 PM
ej_glutton's Avatar
This repair came up on my PPI & I'm thinking of attempting it myself since a honked-up job won't leave me stranded in the centerlanes of I-35. Although I have two degrees in engineering (albeit both civil...we build things w/ bulldozers), I'm not real mechanically inclined & my definition of DIY likely does not match anyone elses. I've heard horror stories about reinstalling door panels & I don't do welding. Is this truly a newbie DIY??? If anyone can direct me to details regarding the repair so I can judge based on my first-hand knowledge of my abilities, that would be welcomed.
Thanks,
EJ
1987 911 Targa
Old 05-14-2007, 09:37 PM
billroth's Avatar
My door was OK and only the stop was broken. Make sure that you tie a piece of dental floss to the bits you are playing with so you don't lose it in the door. No panels had to come off.
The only hard part I found was in getting the damn pin holding the stay to the car door to come out, and putting in the new one. Tight fit and not much room to swing a hammer. Tape the area to protect it from scratches (you can't see it anyway but I was picky).
Lawrence
Old 05-15-2007, 04:09 PM
wahoofan's Avatar
I just did both of mine on a '72 and would like to add a suggestion I found somewhere else on this board. Go to the local bolt specialty store and pick up some M6 Allen head bolts about 25mm long. They make installation A LOT easier!
wahoofan
'72 911T Targa
Old 05-16-2007, 04:44 AM
