Anyone else have loose bulb sockets?
88 Targa. The bulb sockets in the front and rear light housings seem to be pretty loose. Is this a common problem? What can I do to fix it?
I wraped some copper wire around the bulbs and put them back in. They earth a lot beter now.
I cut a thin strip of metal and wedged it in between one loose housing I had.
You can cut some tin foil into strips a little less wide than the bulb and wrap around it.
I wedged split golf tee's in the back ones for the time being, but great ideas above
Tas |
Since I had a parts car, I swapped tail light housings.
| All times are GMT -8. The time now is 04:54 AM. |
