Twin Plug Dizzy Question
Anyone recognise this dizzy?
Can you tell me what model it's for? Cheers http://forums.pelicanparts.com/uploa...1179575958.jpg http://forums.pelicanparts.com/uploa...1179576007.jpg |
Whoops lets try some bigger photos...
http://forums.pelicanparts.com/uploa...1179576385.jpg http://forums.pelicanparts.com/uploa...1179576443.jpg |
Looks like a Magnetti Marelli cap - by the marking on it when I zoomed in on the picture. Turn the top one 180degrees and you can see it.
What it's from I have no idea - measure the gear size and see which way it turns - then it can be looked up. Is there a part number on it? Hope that helps. |
Cam:
Looks like a 906/911R unit but if you measure the shaft just below the O-ring, that will confirm it. For the early cases, that should measure 27mm; RSR ones are 30mm. Further, 906 ones had two sets of points and the 2.8 RSR Marelli's had 4 sets. |
It's a converted 2.7 Bosch dizzy.
| All times are GMT -8. The time now is 04:18 AM. |
