Dino Steering wheel - Horn issues
I have a Dino steering wheel but do not have any necessary pieces to get the horn to work correctly. Is there some special adapter piece I can get and if so, what is it called?
Thanks, David
77 Carrera 3.0 |
I have a collection of Momo buttons and metal surround carroer that is sandwiched between the wheel and the hub David.
Need to drop off your compressor, pick up the green longblock (my 12" block isn't long enough for my hood). Are you going to be around tomorrow morning? I can bring what I have down.
Tru6 Restoration & Design |
Yeah, I had this issue too
I also had an issue with the installation of my Dino steering wheel (and adapter) purchased from Performance Products. To install it on my 1971 911, I had to put the adaptor on a lathe and trim it down until it was the same size and shape as the original steering wheel. I got the steering wheel on the car now (great!) and I'm currently working to see if I can get the horn to work. What is the model # of your Dino and I will check the model of mine, during the meantime. We can compare notes, if you want.
I will be around. Just give me a call in the morning.
I am not sure what it is Andre. I was told there is some adapter but not really sure what it is called. If I think of a work around. I will post. Thanks, David
77 Carrera 3.0 |
