Cable to Electric speedo question
What speedometer will work with a 930 transmission? I am
replacing a cable drive 901. thanks? patrick |
Bird. It's the word...
I stand to be corrected, but I think most of the 'electronic' speedos will work for you, but depending on your engine/gearbox combo, it may not read high enough. I switched from a cable to electronic speedo a couple of years back - no problems.
HINT- when you pull the old cable out, attach a pair of fine wires and use the cable end to pull the wire through the cable outer and bingo; you have your required wires for the electronic speedo.
John Forcier Current: 68L 2.0 Hotrod - build underway |
Thanks, John
I like the idea of pulling the wires through the old cable housing. patrick |
