oil cooler fan wiring
I've reviewed 101 projects and it says to wire the two temp sensor wires to the two fan motor wires.I lack the wire connector for the temp sensor.The cooler housing has a ground connection near the temp sensor.Am I wiring + to the sensor and - to that ground connection or does the temp sensor have a ground or negative terminal contact on the proper wire harness connector?I want to wire in a manual dash on/off switch also.Thanks for your time.Jim.
I think this link will answer your questions:
link1 If not, here is another good one: link2 Let us know if you have any other questions.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
