911R mock up
Hi all,
I'm looking for some help on the layout of the front air duct cut out in the fender of a 911R replica. I have included some pics of my current mock up. The white contact paper is the area to be cut. I laid this out using known R pics, and using the amber turn signal lens as a unit of measure. Any feedback/comments would be appreciated. Thanks, Matthttp://forums.pelicanparts.com/uploa...1179708972.jpg http://forums.pelicanparts.com/uploa...1179709066.jpg http://forums.pelicanparts.com/uploa...1179709228.jpg |
the amber signal is further from the camera so to do proper photogrammetry you'd have to correct for that and for lens distortion....
How close do you want it? |
I'm not looking for perfect, but I would like it to be close enough so it does not to draw attention to that one particular detail.
Matt |
you could calculate the distortion or...
back way far away and use a long telephoto lens centered between the two - that will "compress distance" and reduce that type of distortion - should be plenty good enough also Dave B. / TRE may know the exact sizing - search for his recent thread |
:D :D :D
Matt's car is the one we are trying to get the correct details for ! The duct is looking very close to correct - hard to be perfect when its pictures / lens choice/ distortion in the mix thanks Randy :) |
| All times are GMT -8. The time now is 02:40 AM. |
