Smoking on left hand turns
I have a 74 911 Targa. During a recent event at Road America I ventured into a touring event that allowed us to drive on the track. Coming down Moraine Sweep into turn 5 is a hard left turn and then up a hill. Once completing this turn and looking into my rear view mirror a big puff of smoke would be coming out my rear. Not sure if it was coming out of the muffler or a spill on the heat exchanger. It would only happen following this turn and to some extent into the next turn (six) which is another decent hard left. It didn't happen anywhere else on the track as its mostly right hand turns and some slight lefts. My engine does leak a little oil but its not that bad, maybe a couple of drips a week at the most on the right side of the engine. What would cause this to this to happen and is there anything I can do to prevent this from happening again? I like to drive in drivers ed and some track events everyone once in a while.
Embarrassing to say and to the safety of the people racing In the event I got pulled into the pits and after a quick check I was allowed back on the track after no leaks were detected.
Old 05-21-2007, 09:46 AM
aj88cab's Avatar
45 Views and no post! OK I'll take a SWAG. Your leak may be pooling somewhere and when you make those hard left turns it is spilling on the heat exchanger.......that's all I got....
Good Luck
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 05-21-2007, 12:51 PM
Immature Member
dentist90's Avatar
Is your oil tank filled to the max? Maybe sloshing up into the breather tube and being inhaled on those hard lefts. Check inside you air filter housing to see if its wet with oil.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 05-21-2007, 01:05 PM
I was beginning to wonder if any was out there. Those are some good points. Thank you both for your response. My dad said it might be the breather tubes as well. I'll check up in their for both options. I did have an oil change a couple months ago, after that I did Auto Cross though with no problems. I guess it could be the combination of a hard break, then a hard left and then an acceleration - up hill thus working its way in there.
'74 Metallic Salmon 2.7L more like 3.0L after rebuild. All Updates!
Old 05-21-2007, 01:22 PM
my 74 likes to run just above the min mark on the dip stick or she will slosh up the breather on hard corners. Other option MAKE RIGHT TURNS ONLY !!!
1974 911 targa 2.7 (for the road)
1974 FJ40 Landcruiser (for no roads)
1995 Dodge V-10 HD2500 4x4 (to tow anything I want)
2005 Durango (wifes rig, I've driven it twice)
2000 Fisher Freedom 200 w Mercury 115 ELPTO (because the world is mostly water)
Old 05-21-2007, 02:21 PM
Opened up the airbox when I got home from work today. There was a small puddle of oil sitting in their so that must have been it. I guess I have to get some oil out of the tank- Whats the easiest way to do that?
Old 05-21-2007, 05:57 PM
Easiest way or least messy way? Put a bucket under the engine sump drain and loosen until it starts leaking out. I'd say pull a quart, warm her up and recheck. Or you can suck it out the filler neck with a vacuum pump like this one:
http://www.basspro.com/webapp/wcs/stores/servlet/Product_10151_-1_10001_90755_200002007_200000000_200002000_200-2-7
I use this on my customers boats, it's quick and easy.
Old 05-21-2007, 09:13 PM
