-   -   clock fix if anybody is interested (http://forums.pelicanparts.com/porsche-911-technical-forum/347889-clock-fix-if-anybody-interested.html)
toby1 73t 05-22-2007 03:20 AM
Kind of remember reading that a lot of clocks aren't working, as mine wasn't for 10 years till I told myself its already not working so I took it apart and fixed my clock in about 45 min total on a 73, very easy and quick if anybody is interested I'll post pics and instructions
gumby 05-22-2007 03:32 AM
Great ! please do.
mthomas58 05-22-2007 03:34 AM
Toby, my clock works but white second hand does not. Any ideas?
Thanks!
fanof911 05-22-2007 03:40 AM
Hi
Yep please do , I'm also interested in your fix
Fanof
mthomas58 05-22-2007 03:59 AM
Thanks!
Oops....a search on this subject indicates white hand is not a second hand - it is an elapsed time marker (which explains why I can move it manually). Guess my clock working properly.:rolleyes:
toby1 73t 05-22-2007 04:17 AM
well first i took out the clock, then the three little nuts on the back one has a lock on it I just broke that little piece so the nut could come off, then there are three more nuts on the inside back took those off. Basically its a wind up clock that rewinds every 20 sec or so with a magnet on a spring and a set of points that gives it power to wind. All that was broken on mine was the lead from the power in to the coil. Just tinned the points, soldered on a piece of metal from a resister and clipped it. resprung the little clicker when putting it back together and tick tick first two picks are were the wire was gone next two with resister soldered on. No pics of clipping it but you can figure that out and last two clock jumpered on battery and moving. Also in near the middle of the back a little to the right and up is a adjuster in case its running slow or fast and my second hand dosn't move but the clock moves. Haven't figured that one out yet Hope this helps some of yahttp://forums.pelicanparts.com/uploa...1179832394.jpg http://forums.pelicanparts.com/uploa...1179832421.jpg http://forums.pelicanparts.com/uploa...1179832446.jpg http://forums.pelicanparts.com/uploa...1179832496.jpg http://forums.pelicanparts.com/uploa...1179832519.jpg http://forums.pelicanparts.com/uploa...1179832543.jpg
toby1 73t 05-22-2007 04:19 AM
makes sense on the white hand now i don't have to worry about it thanks
rcecale 05-22-2007 04:51 AM
Toby,
Great fix! Thanks for the pics.
Now I just gotta figure out how to keep my clock from becoming all blurry once I do the repair! ;)
Randy
dlagerstrom 05-22-2007 05:56 AM
The point you soldered is basically meant to be a fuse. They originally used a low temp solder so that if it got too hot it would pop open. If you use standard solder, you run the risk of melting your clock. I put a really small diode in instead as I couldn't find the low temp solder.
I seem to be able to blow up small diodes with enough current so I thought it would be a good substitute for a fuse.
KCinBR 05-22-2007 06:06 AM
Thanks, I too was wondering why the second hand (lil white hand) was not moving
Just too phreaking simple:p
toby1 73t 05-22-2007 06:30 AM
Thanks for the heads up on the low temp solder, think i'll leave the metal from the resister with reg solder and just put a .75 amp in line fuse before the clock. Maybe make it easier next time if it blows the fuse.
tcar 05-22-2007 12:03 PM
There was a guy selling a clock in classifieds about a week ago... said it worked except the second hand.
3.2 CAB 05-22-2007 12:18 PM
I had a clock in mine, it worked fine..., just as long as the engine was running??????? Just as soon as you turned off the car, the clock would go into "REST MODE" and not do a thing until I started the engine again. I guess it would have been a great hour meter of sorts, but you could not tell time. I picked up a used one from Oklahoma Foreign, was about $30.00 at the time. I removed the old clock, plugged in the "new" clock, it has been working perfectly ever since. I never could find out from anyone why the original one was acting like it was. I can't even remember the amount of times I took it out and checked it, but it never did work, except when the engine was running. I am very happy now that I can see what time it is, and the old one is in the box, I guess for parts if ever needed. Just my .02 on this subject.
dlagerstrom 05-22-2007 02:27 PM
Okay, that is really wierd. At first, I thought you must have had a switched power connection that went off when the ignition was off. But if you replaced with another clock and didn't change any wiring, how does the new one work?
The coil that pulls the winder represents an inductive load. Is it possible the battery didn't have enough voltage to kick the coil and with the engine running, the alternator did have enough? Any EEs want to speculate?
3.2 CAB 05-24-2007 07:27 PM
Has worked great ever since. I still have no idea what the deal was. I did not change anything other than to remove old clock and plug in "new" clock. As far as the voltage as being a problem, the car always started and never had any low battery symtoms. It is still a mystery to me???
WolfeMacleod 05-24-2007 07:42 PM
Originally posted by toby1 73t
magnet .........All that was broken on mine was the lead from the power in to the coil.
Did I hear the words "Magnet" and "Coil"?
If someone has a coil that has actually failed, I'll bet you I can fix it.
I would need a broken clock, or at least the coil, to dissasemle and examine. Count the turns of wire, the winding pitch, and the wire guage..
Mount the Coilform to this, and wind away...
The blood of my life:
http://wolfetone.com/images/winder.jpg
juanbenae 05-24-2007 09:28 PM
are you guys kidding on the white hand?
i assumed it was a rallye inspired thing? if you pull the knob out you can move it around the face and "mark" a time. as an enduro rider from way back time and distance can reveal average speed.
you guys really are joking about the white hand right? my take may suck,,, but i had one.
T$
slodave 05-24-2007 10:06 PM
My clock stops every winter - like clockwork. Then when it warms up, it works fine again. It also works in winter, after the car is started or if I move the hands. Living in SoCal, so I'm not talking sub freezing temps here. I have been lazy to take it apart, but looks simple enough. Tomorrow's project.
Dave
3.2 CAB 05-25-2007 11:56 AM
Sounds like the old lube is gumming up in the cooler weather. Probably it just needs cleaning and new lube.
silverc4s 05-25-2007 12:40 PM
Dave
Over the years the clock's lubricant hardens and is the primary reason that the fuse link blows and the clock stops. If you are making on run again, you should clean and re oil it before repalcing the fuse link, or you might eventually get an unwanted electrical event behind your instrumnet panel...:cool:
TerryH 05-25-2007 03:03 PM
Kind of amazing that that clock still works on my '81, but even more amazing is it keeps perfect time. It must of been replaced at some point.
TerryH 05-25-2007 03:06 PM
T$
You think that's weird, I found that to check the oil I had to a remove a cap that read 710!! Strange, but true!
slodave 05-25-2007 03:45 PM
I took mine apart last night. I have the neat-hard-to-remove Quartz clock. I did get the clock apart and when I rotate the gears, I can feel some hesitation - like a small grain of sand is stuck in a gear. I was going to try and clean the gears and re oil.
Dave
toby1 73t 05-27-2007 12:41 AM
that makes no sense to me. if the lubricant hardens all it would do is stop the spring that makes it run the fuse link is only activated in the process of rewinding the spring so if the clock slows or stops it has no effect on the process of rewinding the spring which happens in a split second when the points touch. I don't think you will have any electrical event when you hard wire and put a .75 amp in line fuse right before the clock. Maybe other clocks are build different then mine but I'm sure thats how mine works. On the other hand my clock is running twenty minutes slow every two days so if the adjustment screw on the back of the clock will not correct I'll clean and reoil. i agree that is way his clock would stop on a cold day but i don't think his fuse link is blown or it would not restart.
toby1 73t 05-27-2007 12:52 AM
dave on a mechanical clock like mine I don't think i would ever turn the gears by hand as that very likely can damage something it take s very little energy to keep the osilation (spelling i know is incorrect) of that little wheel going think of a wrist watch not much force winding the spring on the knob. swiss clock were known for workmanship not brute force. Just think thats a bad idea.
