lyon's Avatar
Bosch fuel pump replacement for MFI
I need a new fuel pump, mine has developed a leak.
I was wondering if anyone can recommend an alternative to the Bosch pump for a 2.4 MFI 911?
I hear the Holley might make one that is compatible.
Any info on this subject would be appreciated.
1973 911T
Old 05-23-2007, 10:07 AM
Lyon, the problem is the return line to the tank. I just ordered an OEM replacement. I believe you would need two separate pumps and make sure you get the right volume/pressure on each end. I wanted to retain originality so I bit the bullet. Apparenty Ottos of Venice will do a rebuild for 275$.
Joe
Old 05-23-2007, 01:00 PM
lyon's Avatar
I am just trying to figure out if there are any options before I shell out the money for a new Bosch pump.
I would like to keep originality as well, but the price of the new pumps is pretty high.
I opened up my Bosch pump, put new o-rings in, they work great, the problem that I am having is a small leak from the casing of the electrical on the side of the pump. It is not a bad leak, but I want to take care of it so my car doesn't start on fire.
1973 911T
Old 05-23-2007, 01:48 PM
You can use a different pump but you need to have a capacity of at least .5 gallons per min. and a pressure of 1 bar (14PSI). The system also has to recirculate to cool the injection pump. I think it will be easier to shop around for an original rebuilt pump.
-Andy
Old 05-23-2007, 10:06 PM
spyderman's Avatar
Send a message via Yahoo to spyderman
I used High Pressure Fuel Pump MSD-2225 from Summit Racing in my 70T with CIS. Might be a place to start.
"The probability of survival is equal to the angle of arrival"
1980 911 SC
2002 Boxster (girlfriend's but it lives in my garage)
Gruppe B #099
SCWDP Member 0013
Old 05-24-2007, 02:22 PM
