thrown_hammer's Avatar
Pesky oil leak...
I finally got some time to crawl under the Targa and try to adress the oil leaks. I changed the oil, had a look at the sump screen, and replaced any "wet" gaskets on the bottom side. I also cleaned the oily crud off the bottom of the engine.
I fired it up and looked under the car while I waited for the oil to warm up. Looks like I am getting a drip at the front of the engine. It's dripping directly onto the cross over pipe. About one drip per second. Quite the smoke screen.
It also appears to be coming from up top and leaking down before dipping. What could be leaking up there, and how impossible will it be to stop without pulling the engine? I may pull some FI stuff off and see what I can see.
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 05-14-2007, 07:37 AM
T77911S's Avatar
sounds like maybe the thermostat, if you are lucky. if not, then rear seal or oil cooler/...seal hopefuly.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-14-2007, 09:06 AM
Friend of Warren
thermostat or the oil breather housing.
Kurt V
Old 05-14-2007, 09:26 AM
19 years and 17k posts...
azasadny's Avatar
The nice thing about Webers on these cars is you can easily see and get to the top of the engine and if you need to replace the thermostat or breather housing gaskets/seals, it would be very easy. With CIS, all of those components are buried under the airbox.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 05-14-2007, 10:01 AM
Mine was doing the same thing, leaking from the top and running down along the front of the oil cooler.
I dropped the engine and replaced the gaskets on the breather and thermostat. But the real culprit was the pressure switch which I also replaced. It's a $6.96 part and is the cause of upper engine oil leaks 90% of the time.
PorschePilot
74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration
MID9 Member
Beechcraft V-Tail Bonanza
(Fly'n high and low)
Old 05-14-2007, 01:26 PM
the the is offline
Definately check out the oil pressure switch on the top of the engine.
It is made up of a plastic piece crimped inside a metal piece, and it starts to leak quite often.
Easy to swap out on an SC, no need to drop the engine or anything, just need to remove the air filter cover and the CIS boot.
Old 05-14-2007, 01:43 PM
dweymer's Avatar
Been chasing the same leak:
Breather gasket
Double check breather hose for tears and clamp damage
Pressure switch
Crush ring for pressure switch adapter-not sure if yours has one
Thermo-oil ring
Is the airbox wet inside? If so it may be an overfull situation, although you've been around longer than me, so I am sure you know how to fill it
Donnie
Currently Porsche-less.....
Old 05-14-2007, 01:52 PM
I will pull off as much as I can to see what I can.
1975 911S (sold)
Old 05-14-2007, 06:01 PM
Not gonna get to it from the top. Looks like it's time for my first engine drop. And I thought we would actually get to drive the car this year.
1975 911S (sold)
Old 05-19-2007, 10:02 AM
Marco8's Avatar
Hey, before you do that engine drop, read some threads on this topic!!!! I had that problem w/ my 3.2 and the fix was 2 hrs and $12 (thermostat o-ring and pressure switch). I realize with a CIS engine it is harder to get to these items but from what I remember several people accessed these with a partial engine drop of a few inches. (do a search on thermostat o-ring and oil pressure switch).
Good luck and hope you can avoid the complete drop.
Marco
96 993 coupe
88 911 cab (gone, but not forgotten)
Old 05-19-2007, 10:13 AM
Marco,
I talked to some guys and looks like the partial drop might be the way to go.
1975 911S (sold)
Old 05-22-2007, 06:38 AM
Marco8's Avatar
Shawn,
Great, a partial drop a whole lot easier then a complete drop. Good luck tracking those leaks down.
Marco
96 993 coupe
Old 05-22-2007, 04:38 PM
