-   -   Help identifying a wire please (http://forums.pelicanparts.com/porsche-911-technical-forum/347992-help-identifying-wire-please.html)
Tim Casey 05-22-2007 04:35 PM
This wire enters the front trunk area next to the small washer pump. As it is brown, i want to believe its a ground...but it has a terminal connector attached (PO). so i am unsure if its a power lead or if it was initially attached at the body ground.
It appears to be factory...The picture isnt the best...
Any help appreciated!!http://forums.pelicanparts.com/uploa...1179876879.jpg
rattlsnak 05-22-2007 06:53 PM
its definitely not factory. They would not run a wire through the sheet metal without some type of grommet. Where does it go? aftermarket fog lamps? cooler fan?
Groesbeck Hurricane 05-22-2007 07:15 PM
Could you post a little clearer photo and a photo of where the other end of the wyre goes? Thanks.
Tim Casey 05-23-2007 04:31 PM
I will try to get a better shot. I assummed it may have been factory just because of the way it comes thru the sheet metal. I can't see where the other end goes as of yet, that hole is covered by the front bumper. No aftermarket lights, alarm, etc. everything appears to be original.
Tim Casey 05-23-2007 06:15 PM
Seems like someone would have gone thru a lot of trouble to fish this....http://forums.pelicanparts.com/uploa...1179969325.jpg
group911@aol.co 05-23-2007 08:12 PM
Not factory. Maybe remote radar, alarm ????
Groesbeck Hurricane 05-24-2007 04:41 PM
Where does the end coming towards the camer go?
Looks like some other wires spliced in there as well.
