Brad w's Avatar
80 SC oil leak
Trying to track down a oil leak. I thought it was from the right side valve covers but after replacing them I still have a leak. It appears to be on the right front. It leaks off the valve cove at the bottom front corner just behind the oil cooler. The cooler seams to be leak free. Any suggestions?
Thanks Brad
Brad W 1980 911 SC
1982 928 Auto
1982 928 5spd Comp PKG
2005 SLK 350 w/ AMG Pkg
2007 Hummer H3
Old 05-28-2007, 05:34 PM
On my SC i chased a leak in the same area that turned out to be rocker shafts. After putting in rsr seals on the rocker shafts its clean as a whistle.
Old 05-28-2007, 05:43 PM
curious, do you need to remove engine to do "rocker seals"
Old 05-28-2007, 05:46 PM
I didn't. Its quite a pain in the fingers, arms, back etc. I shortened the big allen wrench for the ones on the end of the motor.
Be careful not to drop the nuts or retainers in the motor, had one scare. Mostly they will push out when loosened. I had a couple with burrs that needed more coaxing with varieties of screw drivers and drifts at weird angles.
Its easier to do when out. especially the drivers side. I think I left the top side alone on the drivers side for when the motor does come out, clutch due soon.
Probably should do the adjustment while your there, I went back and adjusted the valves later and they needed it.
Old 05-28-2007, 05:58 PM
Old 05-28-2007, 06:02 PM
Brad w's Avatar
Do you have a part # for this?
Brad W 1980 911 SC
1982 928 Auto
2007 Hummer H3
Old 05-28-2007, 06:23 PM
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_ENGcam_pg2.htm#item7
99-0579-052-M260 Rocker Arm Shaft Inner Seal (used originally on RSR cars only, sold per each, 24 required) 911 (1965-94), 914/6, 911 Turbo (1976-94)
Old 05-28-2007, 06:26 PM
