-   -   915 Question - what have I done? (http://forums.pelicanparts.com/porsche-911-technical-forum/348576-915-question-what-have-i-done.html)
DelPico 05-25-2007 08:16 PM
Ah stupid mistake I made while changing my tranny fluid. I took out a bolt on the right side, that had a spring behind it. It was the bolt, a washer and this spring in the hole. The spring never came out. Anyways, did I mess something up with my reverse. It seems to drive the same 1 - 5. Doesn't like to go into reverse with engine running. Not sure if this is related, it has acted funny in the past going into reverse.
Any suggestions? Not that big of a deal I think. Just don't put in reverse while engine running.
Thanks,
Eagledriver 05-25-2007 11:05 PM
That is a detent spring for your shift rods. As long as nothing fell out and you put the plug back in with the spring you don't have a problem. There is a ball in there the spring pushes on and the ball goes into a detent on the shift rod to make it stay in place when the car is in gear.
-Andy
ChrisBennet 05-26-2007 05:14 AM
-Andy
Actually, it's not really a "ball", it's pill shaped on a 915.
-Chris
Porsche_monkey 05-26-2007 07:09 AM
-Chris
Actually, it's not really a "pill", it's capsule shaped on a 915. ;)
dentist90 05-26-2007 10:08 AM
Not going into reverse without grinding is a sign that your clutch isn't fully releasing. Check on this... sometimes a simple adjustment at the clutch pedal.
DelPico 05-26-2007 06:10 PM
thanks all.
