oly oly is offline
1985 Carrera Coupe
Question Will GT3 seats fit in a 3.2 Carrera?
Has anyone tried this combination? I thought that I read somewhere that the top wings interfere with the interior of the car near the b-pillar.
Art
Old 06-04-2007, 05:18 PM
YES
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 06-04-2007, 05:36 PM
If you don't mind the quick hijack, would GT3 seats fit a long hood?
I'm considering them for a 1970 RSR clone. Thanks.
Old 06-04-2007, 06:40 PM
Now in 993 land ...
aigel's Avatar
I have seen them in a 993 - that should be the same basic interior dimensions than any air cooled 911. In the 993 it is far from a direct bolt in, I was told.
Cheers, George
81 SC (sold)
Old 06-04-2007, 07:06 PM
boba's Avatar
Is this the seat you are interested in using?
To mount this in an early car you will need to mount it on the floor. This will require the removal of the existing seat mounts.
The mount on the floor should then be reinforced.
As my car is open I cannot comment on clearance at the B pillar.
Old 06-04-2007, 07:38 PM
Bob,
Yes, those are the GT3 seats I'm also considering for my car.
I was told they're very much like the Pole Position seats except for the top portion by the shoulder harness holes. At this point, I can not easily modify the factory mounts, lots of stuff is already running under the tunnel as well and would not want to cut/weld on that area.
Can you think of any other way to mount these with the factory mounts? A custom mount is doable specially if it can be bolted down to the existing hardware. Here is one made for sparco seats.
This is what my mounts look like - old photo, in this photo the tab/mounts are not shown closest to the doors, but I do have them.
Old 06-04-2007, 08:23 PM
boba's Avatar
Fernnando,
My seats are the 996 seats and as you can see the spacing of the factory mount is too wide for the normal seat mounts in the tub of a longhood thus the mods. You can see the mounting holes in the floor in the pics. I am also tall so getting the seat down is also an advantage for me. I do not know if 993 seat would fit inan early tub, but it would be worth looking into.
Good luck.
Old 06-04-2007, 08:44 PM
Tim,
That's a clean install, I like it!
Thanks for the tip on the part nubers, it's good to know the GT3 993 and 996 seats are the same except for the mounting brackets/sliders.
Thanks for the closeup pics Bob, lucky for me, I'm not that tall
Old 06-04-2007, 09:09 PM
MIK911's Avatar
There's a pic somewhere on this site of a 80's SC or 3.2 targa with those GT3 seats in it. HOT.
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 06-04-2007, 09:52 PM
oly oly is offline
1985 Carrera Coupe
boba,
Yes, that IS the seat that I want to use. I like your installation especially since it looks like it will maximize head room. But I prefer not to cut into my car. Hopefully I can find some adapters so that I can use the factory mounting points.
Art
Old 06-05-2007, 01:51 AM
shahram's Avatar
GT3 Seats in 3.2 C
it was a direct fit for me:
Old 06-06-2007, 11:49 AM
I have already replied to Oly's PM and given him photos but I thought I would post here also for the benefit of the board........
Seats installed with no clearance problems. New sliders and brackets were required.
regards,
Phil
cheers,
Phil
84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies.
Old 06-06-2007, 12:00 PM
This Way Up
rdrr's Avatar
Phil, those look great!
Old 06-06-2007, 12:17 PM
Thanks Hardi.
Not to hijack this thread but these are great on the track. Contibuted to my almost 4 sec improvement at Wakefield.
I found them not as comfortable as the stock ones for long distance though and got a bit uncomfortable after a few hours.
Phil
cheers,
Phil
Old 06-06-2007, 12:31 PM
Phil,
If you don't mind me asking, where did you get the brackets and sliders? The brackets you're using have quite a bit more adjustement than others I've seen. Thanks.
Old 06-06-2007, 12:35 PM
I didn't source them myself.
I'll try and find out what brand they are but don't forget we're way down under here so may be local......
cheers,
Phil
Old 06-06-2007, 01:38 PM
oly oly is offline
1985 Carrera Coupe
shahram,
Thanks for the pictures! What company made your brackets?
Art
Old 06-06-2007, 05:44 PM
oly oly is offline
1985 Carrera Coupe
sus911
Thanks for the post. I have the same source question as SoCal70RSR.
I did not get your e-mail; my inexpensive e-mail provider probably would not accept it because of the size of the picture files.
Also, how DO you guys manage to get anywhere with those right hand drive cars?!? Everything is in the wrong place accept for the relative pedal locations... Just kidding! I'm a left hander so I'd probably be a better shifter if I were living on your continent.
Art
Old 06-06-2007, 05:55 PM
shahram's Avatar
Oly,
is long ago. I guess from summit racing.
Shahram
Old 06-07-2007, 12:27 AM
oly oly is offline
1985 Carrera Coupe
shahram,
What year is your car?
Art
Old 06-07-2007, 01:00 AM
