-   -   coil datas (http://forums.pelicanparts.com/porsche-911-technical-forum/348656-coil-datas.html)
philippeF 05-26-2007 11:07 AM
coil datas
Hello
Would you give me the resistance values to test my CDI coil, please ?
regards
Philippe
HarryD 05-28-2007 09:39 PM
Philippe,
Whenever you have a question on Porsche Electronics, chances are that "Early_S_man" has already answered it. Do a search with him as the "User name" and the terms you need to find out about.
Using coil and ohms, you will find this post:
http://forums.pelicanparts.com/showthread.php?s=&threadid=299530&highlight=coil+o hms
This should have your answer.
What is the problem you are having?
philippeF 05-29-2007 08:59 AM
thanks
I've found this values, thanks
My problem, is sudden engine cut off (2.7RS engine), i'll try to eliminate electrical or ignition causes, if you have ideas....
regards
Philippe
HawgRyder 05-29-2007 12:01 PM
Buy an MSD coil....#8222....relax....never have another though about bad coils again!!
Bob
philippeF 05-29-2007 12:57 PM
thanks Bob
I've found a black coil ...
does your MSD have the same primary and secondary numbers ?
regards
Philippe
HarryD 05-29-2007 05:43 PM
Hi Phillipe,
Lorenfb posted this on another thread (http://forums.pelicanparts.com/porsche-911-technical-forum/341881-do-i-need-replace-my-cdi-box.html?highlight=coil). It should help you with your troubleshooting:
Loren sez:
"The diagnosis of this problem should take at most 5 minutes:
1. Get ANY known good ignition coil.
2. Make sure that the center pin of the CD box has a good +12 volts.
3. Make sure that the CD box case has a good ground.
4. Connect one terminal of the known good coil to the CD box output.
5. Ground the other coil lead.
6. Momentarily ground the pickup lead to CD box which will produce
a spark each time. Make sure nothing else (points, special pickups)
are NOT connected.
It's that simple!
Check here for additional info & specs (coil & etc.):
www.systemsc.com/diagnostic.htm
