Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Danny_Ocean's Avatar
R134 fittings vs. R12 fittings?
Are the re-fill fittings on the compressor the same for both R134 refrigerant vs. R12? Can you "accidentally" fill a R134 system with R12 or are there two completely different fill adapters?
Old 05-26-2007, 12:01 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
sudo apt-get purge 930
equality72521's Avatar
They are completely different for just that reason.
--clutch-monkey
Old 05-26-2007, 12:08 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Whew...thanks.
Old 05-26-2007, 12:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
3.2 CAB's Avatar
There is not really an easy answer for these questions. If it was converted properly, you should not be able to get the two mixed, but if not properly converted or altered, watch out. Here is why. If the compressor was originally a R12 compressor and someone converted the system to use R134a, you could still possibly have the R12 fittings on your fill ports. If is was done as should be, there would now be the R134a type fittings on it. If it was a R134a factory type replacement compressor and the other parts had been changed to R134a type equipement, it should be R134a only type fittings on it then. I have seen R12 systems that have been changed to R134a, and they still have the R12 fittings. There is a lot of differences between the R12 and the R134a fittings, you can't mistake them. Yes, you can accidently fill a converted R134a system with R12, only if they left the R12 fittings on it. The fittings themself are so far apart from the function and operation, one will not interchange with the other. That is, like I stated, if someone did not properly change out the fittings. The kits to convert, have the various fittings that are required for the change, plus they also have WARNING stickers, to warn that the system has been converted. I have also seen some, not so much on the up and up, used car dealers, actually top off a R12 system car with the much, much cheaper R134a out of the 30lb jug, by using a hose end adapter, without ever changing the cars fittings or placing warning labels anywhere. Then the "new" buyer wonders why their A/C quit just a day or so after they bought it. SCUMBAG USED CAR DEALERS!!! Hopefully some others will respond and give you their opinions on this subject. Good luck.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 05-26-2007, 12:30 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
I purchased an R134 re-fill kit which (I assume) has an R134 adapter on the fill hose. The fill hose fit perfectly on my compressor and charged the system.
So...I think I'm OK, yes? If my system was still R12 (or an R12 conversion done improperly), my R134 hose wouldn't have fit...?
Old 05-26-2007, 02:52 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
If your system was originally R-12 but now has the R-134 fitting which it sounds like it does since your R-134 refill kit fit, then you should be fine.
Scott
1988 Porsche 944 Turbo S 70,000
1987 Porsche 911 107k (sold)
1982 Mercedes 240D 4-Speed (mileage unknown)
1998 Mercedes E300 Turbodiesel 147,000 (sold)
1985 Mercedes 300D 227,000 (sold)
Old 05-26-2007, 03:26 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
