Acetone OK for rear window tint adhesive removal?
Fortunately, my rear window tint peeled off in one/two big sheets. Now I'm left with the glue...
I parked the car in the sun and let the glue get "gummy". A rag soaked in "Goo Be Gone" removes it, but takes a whole lot o' rubbin'... Is acetone safe to use on the interior of the windows? I remember reading somewhere that certain windshields are coated (safety glass?) and this coating can be damaged if too harsh a chemical is utilized. P.S. - I did a search here for tint removal, but couldn't find anything indicating acetone was OK/Not OK... |
I'm sure you can find something much less nasty than acetone that will work.
If its a heated window, which i assume it is i wouldn't touch it with acetone. keep on rubbing i say
Classic 1969 911T |
Ammonia is the solvent of choice for window tint glue
DonMo 1984 911 Carrera Targa 3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip Columbia, SC "Go Hokies" |
