fuel pump
I have the cis system on my car, I was wondering if I could upgrade the fuel pump in my car to something else.
What type should I get, or should I?
Has anyone else upgraded their fuel pumps?
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 05-27-2007, 02:01 PM
fuel pump
Napa sells a pump pump that is a perfect $120.00 replacement for the $650.00 cis pump.
Old 05-27-2007, 02:41 PM
I replaced the pump in my 1977 S tub with a Bosch 044 motorsport fuel pump as a safety measure because the 930 motor might need more fuel now it's tweaked...
The 044 pump cost $199, and is one of the highest spec pumps Bosch make, apparently is conseratively rated, and out-flows and out-performs pumps from other manufactureres that are supposed to be comparable.
Standard fitment on Cosworths and widely used on big HP motors and WRC cars.
Bosch have a universal fuel pump program, hardest thing might be finding your original pump #, but this might help:
http://apps.bosch.com.au/products/saa/efi_crossref.pdf
http://apps.bosch.com.au/products/saa/efi_techserviceparts.pdf
http://apps.bosch.com.au/motorsport/downloads/fuelpumps.pdf
http://apps.bosch.com.au/products/saa/efi_vehicleapplications.pdf
'77 S with '78 930 power and a few other things.
Old 05-27-2007, 03:46 PM
Thanks guys
Thanks for the info, I will pursue this further and see what my budget will allow....
thank you again.
Old 05-27-2007, 06:05 PM
