Registered Loser
My power windows worked today - but why?
My power windows worked today. That is odd because my driver side window became intermittent early in the Fall and then stopped altogether. But today it worked just fine. Of course, the only that has changed is that the temperature was almost 60 degrees today (very unusual here in New England). Any ideas?
Owner of a wrecked 944
Old 01-09-2008, 07:58 AM
kqw kqw is offline
Check you window switch (behind) the door panel. There should be a rubber boot covering the switch terminals preventsing moisture from getting in there.
The Fox
Carrera
Old 01-09-2008, 08:33 AM
gerrygug's Avatar
+1 on moisture
2000 Boxster S
1984 Carrera
1976 912E
Old 01-09-2008, 08:37 AM
petrolblue83911's Avatar
the switches go bad, work sometimes then not and back again...a new switch will generally fix it. beware however that the new switches you can buy have a different texture than the old ones, so you may want to buy 3 and replacea all so they match.
Old 01-09-2008, 09:21 AM
Driving member
jester911's Avatar
In my car when I had intermittent windows it was from the wiring to the power drivers seat grounding out on the floor pan. Maybe something to check.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 01-09-2008, 09:24 AM
cjbcpa's Avatar
Do you have a sunroof and does it work? In my '86 Carrera, both the power windows and sunroof worked intermittently and then stopped working. This was corrected by replacing the power window control module located behind the instrument cluster. The telltale sign for this was that there was no power across the terminal in the fuse box. In my case this was an easy fix, $38 part and it was accessible through the luggage compartment.
CB
Old 01-09-2008, 09:54 AM
