Warped Rear Targa Shelf
Has anyone successfully heated and straightened the warped plastic piece at the top of the shelf shown below? Alternatively, anyone have a brilliant idea on how to replace/repair this NLA piece? Thanks! -- Curt
Old 05-10-2002, 08:51 AM
Hmmm, no replies so I decided to fire up the torch and give it a try. Not much to lose I suppose. I gently warmed up the plastic (with the vinyl and foam backing still attached). Worked it around by hand a bit and then pressed it down against a sheet of plywood with another board. I'd say there's a 90% improvement! Not perfect, but much, much better than before. I'll try to fine tune it a bit more tomorrow. -- Curt
Old 05-10-2002, 05:34 PM
makaio's Avatar
Curt my coupe has the same problem. I've been planning to $hit can it when I get the RS America carpet set.
But heating it with something and pressing it into shape seems like a good idea.
Old 05-10-2002, 05:50 PM
tangerine911S's Avatar
Very old thread I know but wondering if anyone else has some information about this. Mine is warped and im about to try this method. I dont own a torch... would a hair dryer be hot enough? Thanks.
Brian
Old 06-02-2007, 09:02 AM
Semper drive!
rcecale's Avatar
Brian,
I would think a hair drier wouldn't generate enough heat.
You could try a heat gun on the thing, which should soften it up well enough.
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 06-02-2007, 09:51 AM
CurtEgerer's Avatar
The heating method did work well. Unfortunately, it is now 5 years later and the sun (and engine heat) has worked its magic again - it's pretty much warped just like before. The solution is probably to fabricate a new piece out of different material.
1983 AUDI Turbo Ur quattro
1987 PORSCHE 944 turbo
Old 06-02-2007, 10:15 AM
