dshepp806's Avatar
89 G50,..something's "moved or loose"
Greetings to all,
Productive day with the 89 coupe,..taking care of many side items,...ending on a (somewhat) bad note........need you guys' insight before I embark.
Today's drive produced something in the G50 shifter that doesn't feel right...(BTW,..today's work had NOTHING to do with the shifter...). At a red light,....placing shifter into 1st,..preparing to GO,..I noticed something felt as if something loosened within the shifter...she's going in all gears just fine yet there's more lateral movement (left/right) while in neutral. While pulled over on the interstate, I noticed that when moving the shifter left to right (neutral), I can hear a slapping (if you will) of what seems to be metal tapping metal that was not there before. This shifter and tranny have been working flawlessly previously. I headed on down the road, carefully and sensitively, noting that she's getting in the gears just fine,.still quite nervous that something just loosened,..I carefully headed home to be distracted with the non-Porsche activities for the remainder of the afternoon, unnattending to my new-found problem.
I've spent much time this evening reviewing many great posts, particularly on the console removal, linkages, etc. and am prepared to indulge tomorrow (Memorial day).
Guys,..which part (in PET) on this shifter may have loosened (or broken)? The sound (when moving the shifter while in neutral to the far right (((TAP))) seems to eminate from under the E-brake area. GEEEEZE,..I hope that only some screw or something has come loose and can be tightened...maybe she's now free to move within the tube?
Maybe you experienced fellows already know what has "taken' place"....
I hope my description is sufficient and not too confusing.
Delicate shifting provides all of the normal excitement she's always had...just that this lateral slop is not at all normal,..that's for sure.
Thanks in advance for insightful observations.
My best
1989, Carrera 911, 3.2L, G50, S.A. Edition
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-27-2007, 07:13 PM
dshepp806's Avatar
I might add that the lateral slop can be felt while in gear,..slightly..
Thanks again, guys,
Middle Georgia
Old 05-27-2007, 07:15 PM
cicsprog's Avatar
I'd bet the bushing.....mine went kaput too....here's a good thread about that:
G-50 transmission gear shifter loose
I don't remember what mine acted like, but I remember I could tell something wasn't right.
Hope that's it. Easy fix and cheap.
Jason
88 CAB
Old 05-27-2007, 07:32 PM
dshepp806's Avatar
thanks, cicsprog..I'll have a read............still curious: so this shift rod bushing would allow this lateral SLOP I'm feeling?
Best,
Middle Georgia
Old 05-27-2007, 09:29 PM
Eric Coffey's Avatar
Before removing the console and tearing into the shifter, you may want to inspect the coupler (access panel under carpet aft of the e-brake).
Old 05-27-2007, 11:27 PM
From the sound of it, I suspect that the hard plastic shift rod bushing (950 424 224 03) went to the tunnel in the sky. I think that there are two: one in the shift housing and one in the tunnel. Just buy the whole kit that PP sells and do all of the plastic bushings and o-rings at once.
G-50 shift tower bushings
The tapping you hear is the shift rod hitting the shift housing and/or the sheetmetal shift rod support built into the tunnel.
All in all, an easy fix and one you likely won't have to do again for 100k miles.
CConnor
73E targa
89 Coupe
Old 05-28-2007, 01:19 AM
dshepp806's Avatar
good point Eric. I will do just that (first)
Crachian: thanks for your observations. I now have my Bentley back in hand this A.M. and am studying the layout presently....
Thanks again, guys. Let's see how this ends...
Best
Middle Georgia
Old 05-28-2007, 05:02 AM
A Marchand fan before you
Por_sha911's Avatar
My shift suddenly got sloppy in 3-4th. Turned out to be the ball cup. See: this thread
Joe
Old 05-28-2007, 02:48 PM
dshepp806's Avatar
And what was the answer to your last post in stated thread? Just curious..
Thanks for the info.....still trying to decipher the part numbers ..
Best,
Middle Georgia
Old 05-28-2007, 09:01 PM
Por_sha911's Avatar
Put the new ball cup onto the ball and then install into the shifter. I used a little white lithium grease and it popped right in.
Joe
Old 05-29-2007, 05:02 PM
dshepp806's Avatar
Thanks, Joe.
Middle Georgia
Old 05-30-2007, 01:31 PM
Fronnzy's Avatar
Hi, this happened to me today. Exactly as first post described it. its certainly 950-424-224-03 the white plastic bushing, as it is broken in half. The PO replaced this days before I bought (2000 miles ago), is that a complete fluke or could something else be going on??
Thanks,
B.
Bjorn
1987 911 Carrera
2001 Volvo XC70
Old 08-13-2007, 07:07 PM
Fronnzy's Avatar
Is the kit you are referring to 10-1518-090-M230 (G50 Improved Operating Shaft & Bushing Kit)
Thanks,
Bjorn
Bjorn
1987 911 Carrera
2001 Volvo XC70
Old 08-13-2007, 07:10 PM
Por_sha911's Avatar
Originally Posted by Fronnzy View Post
Is the kit you are referring to 10-1518-090-M230 (G50 Improved Operating Shaft & Bushing Kit)Thanks,Bjorn
No, that is for you clutch release fork. What we are talking about are two plastic bushings in the shift and shift linkage. Both can be gotten to from inside the car and are very easy fixes. Click the link that I posted on 5/28
Joe
Old 08-13-2007, 08:36 PM
Fronnzy's Avatar
Ding Ding Ding - Viewer discretion advised!
Well sir, you are correct!
Here is the culprit...
Here we see old bones in the bushing grave yard.
What is this all about??? The previous owner replaced this days before I bought the car, less then 2k miles ago. Why would it break again? I can't find the broken piece of the new white bushing, but look at all the broken bits in the bottom of the casing.
Bjorn
1987 911 Carrera
2001 Volvo XC70
Old 08-13-2007, 10:01 PM
I just went through this in my 88 911. This must be age related ! I replaced all the bushings in there....hey, while you're in there. I used Super Lube on everything, shifts
really nice now. I replaced the bushing #12 above and the ball joint bushing, also the
"O" rings #11
Old 08-14-2007, 06:38 AM
