Oil pressure at WOT
What are acceptable oil pressure numbers at full throttle?
My ignition is retarded. |
You would like to see around 10PSI for every 1000 RPM. Although not everyone will agree, I think is pretty much the standard for most HP engines.
5000RPM=50PSI
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Thats what i have always heard, 10psi-1 bar for every 1000rpm. Is it linear up to redline?
Slumlord
Should be linear, 1 bar / 1000 rpm.
Is yours non-linear?
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Many cars are not linear. Later 911 (964,993) cars seem to have higher oil pressure at idle and low RPM than earlier cars. Porsche has a spec for each car. The guidance of 10 PSI to 1 bar per 1000 RPM is a good guide for early cars. Throttle position should have no effect on oil pressure except to influence the RPM the engine is at.
-Andy
72 Carrera RS replica, Spec 911 racer |
If you imply WOT = max rpms then the oil pressure should be @ 5bars (maxed out).
I should probably have added that the motor is a twin plug 3.5 making about 270rwhp. I have pretty aggresive cams, so my idle is about 1300 with 40psi oil pressure. Oil temp is generally around 150-180 unless it is really hot or i am stop and go. Normal driving and midrange acceleration pressure stays between 60 and 100, but if i really romp on it it will spike up above 100 and drop back down in betwen shifts.
After doing some research with the search button, i am not as concerned as i was, but i'm still going to check the sender and pressure with a mechanical gauge. Paul
