Relay internal functions
Need to know the internal functions of the common 911 electrical relay(30-85-86-87).Thanks.
30 is battery positive voltage
87 is a relay actuated contact 86 is the coil control voltage 85 is coil ground |
Here's typical Bosch DIN relay, 1 make, 1 break type. 87a is typically not included on the round relays; used to break a circuit when the relay is energized. Othewise, the function is the same.
http://forums.pelicanparts.com/uploa...1180472784.jpg 86 is also source voltage. When switched, it energizes the magnetic coil in the relay, then to ground. Sherwood |
| All times are GMT -8. The time now is 05:55 AM. |
