-   -   Fuse Panel Numbering (http://forums.pelicanparts.com/porsche-911-technical-forum/349190-fuse-panel-numbering.html)
Kaliv 05-29-2007 03:53 PM
I'm was trying to replace my A/C fuses and found that fuse #9 is one of them. The diagram that came with the car however is someone incomplete. Could anyone help me figure out the missing pieces?
Relays seem to go in reverse order... F E D C B A.
The fuses look something like this...
?? - 10, 1-8
21
There is an 8 block to the right that reads left to right. But the block next to it starts at an unknown number and ends with 10. Where would fuse 9 be? And then fuse 21 is listed below, but I don't have anything there.
Car is a 1987 Coupe.
Wil Ferch 05-29-2007 04:41 PM
The various Porsche spec books seem to number the fuse block first one way...then the other way...to get you madly confused.
The 84-89 3.2's were basically the same but there were minor differences.
The square shoulder of the fuse block faces the front of the car, the slanted shoulder in back. So...the front-most fuse block has 8 positions, the next one back has 10, and the rear-most has 3. The Bentley manual counts the fuses back-to-front. Starting from the rear most unit, they are 1,2,3. This is called fuse block #3. The next block also counts back-to-front and counts 1-10. This block is called ( oddly) fuse block #1. The block closest to the front ( fuse block #2, go figure) continues this way and counts 1-8 towards the front.
For the A/C on an '87, block # 3, position 2, is a 25A, A/C fuse.
Block #1, position 5 is a 16A control unit fuse for A/C and heating.
The pocket Tech-Spec books identify the relays A, B, C.... front-to-back ( again...go figure...reverse direction of fuse numbering !)
- Wil
