LinkBack Thread Tools Rating: Thread Rating: 7 votes, 3.86 average.
Originally Posted by jhubs View Post
89911,
I noticed that some of the bumper mods have a dimple where the rubber strip was and your bumper does not have that dimple. Could you explain? Thanks! Jerry
The dimple looks like some deformation from welding? Ususally just a few bolt holes that need filled and leveled.
Old 11-24-2007, 12:52 PM
Here is the bumper prior to the work.
Old 11-24-2007, 12:54 PM
jhubs's Avatar
Ok, Then it must be that some years had the "dimple" and other years did not.
I dont mind it, but I was just wondering. Your photo shows that your unfinished bumper did not have the dimples to start with.
This is not my car...
Thanks,
Jerry
1995 993 Carrera, Guards Red Coupe (current)
1987 911 Carrera, Marine Blau Metallic (06-08) Gone but...
1965 Yellow Mustang Convertible (65-05)
__________________________________________
It is always a good idea to keep the pointy end going forward as much as possible.
Old 11-24-2007, 01:30 PM
SCWDP911's Avatar
gsmith, any new updates on your bumper project?
Shane
- Daily - 2004 Cayenne S
- Gone but not forgotten - 1983 Ruby Red Cabriolet
Old 12-08-2007, 11:00 PM
Bill Douglas's Avatar
I think it would look nice if the accordian rubber was removed and the next bit of metal was fabricated to meet and slightly overlap the bumper.
That red bumper is nice. More like waxed than shaved.
Old 12-08-2007, 11:56 PM
Happiest when Tinkering
gsmith660's Avatar
only update is the alumaweld didn't work well I suspect it is because it is a large heatsink and would work well on small projects. I am now going to get it TIG welded the guy who will do it will wait till he has a head to repair and only setup once.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 12-09-2007, 04:57 AM
Never left, but not right
Zeke's Avatar
What would the rear section look like upside down?
Old 12-09-2007, 08:03 AM
cycling has-been
bkreigsr's Avatar
Milt, the rear bumper is not symmetrical. The top lip is about 1-2 inches deeper than the bottom. But, as I have seen here, anything is possible.
Do you mean to flip the bumperettes also, or go with a shaved look?
Bill K
Old 12-09-2007, 02:44 PM
gsmith660's Avatar
Bumper going to get welded today I will post pictures of the completed welds and the finish jb weld work.
Old 01-29-2008, 10:30 AM
81turboporsche's Avatar
Send a message via AIM to 81turboporsche
do you have any side pics of the bumper where it meets the rear quarter panel,im getting my car out of the body shop next weekend and im warming over alot of ideas,that look is clean and beautiful and im pretty impartial to deleting those bumperettes
Old 01-30-2008, 08:17 AM
gsmith660's Avatar
Mine is going to still have the bellows so there is still some functionality of the bumper as an impact bumper but all the other rubber is gone and holes will be filled.
Old 01-30-2008, 08:47 AM
cdrik915's Avatar
The lighting is realised with the factory parts , just adapted in the bumper .
Old 01-30-2008, 08:56 AM
Banned for Life
RSBob's Avatar
Originally Posted by 89911 View Post
I used these guys:
http://www.truckaddons.com/Catalog/subpages/DEI_lightnbolts.htm
and just used the old wiring. Drilled one hole behind the plate and ran them to both. You can use any plate you want.
The ultimate in clean looks - best I've seen yet! Doubt it can get much better than that. The plate lights are what makes it work.
Rick S, '71 914 3.0, '82 911SC EFI, R Gruppe #309
Old 01-30-2008, 09:52 AM
Perfect timing for this to re-emerge... I am in the process of cleaning up my rear bumper. Assuming that I am not going to weld studs to the back, what type of fasteners are you guys using to secure to bumper to its traditional crash tubes? Obviously I would prefer the most unnoticable types.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 01-30-2008, 12:10 PM
gsmith660's Avatar
I got brackets welded to the inside of the bumper and popped out the studs on the shock tubes and am using jb weld to fill the holes and secure bolts in the stock holes I will post pics when I get the bumper back from the welder and by the way the TIG welding only cost me 15 bucks!
Old 01-30-2008, 12:28 PM
SCWDP911's Avatar
cdrk, thanks for posting your pic over here. That is one beautiful car. I am interested in seeing more of your plate lights. Can you post some more pics?
Shane
Old 01-30-2008, 12:48 PM
SCWDP911's Avatar
Originally Posted by bkreigsr View Post
those look like the lights that are inserted into the bumperettes. with the factory seals and gaskets in place, they should be okay in the weather.
btw, my bumper is in the shop for paint as we speak. I've got over 150 hours in modifications and adjustments (on and off since mid Nov.), primarily to get some air flow around the turbo, secondarily to lighten the rear up a bit. Actually it was Noah's old silver euro, so my original remains intact.
Bill K
Any teaser pics? 150 hours? That thing sounds like another piece of bumper art on the way...
Shane
Old 01-30-2008, 02:24 PM
cycling has-been
bkreigsr's Avatar
teaser - taken mid Dec.
definitely not for everyone, and the end result is quite unique.
on the final version, I tried to retain as some impact protection, so I will be using euro bumperettes and rub strips.
Old 01-30-2008, 03:07 PM
very cool BKREIGSR.
I wonder how well the factory license plate lights light as in the bumper guards they are perpendicular to the bumper. I used the rub strips also as I like that look and wanted to to match the front bumper.
I used thickened epoxy to fill the bumper guard holes, worked fine.
O2 In Sully We Believe
Old 01-30-2008, 03:30 PM
SCWDP911's Avatar
I think that will look cool BK
Shane
Old 01-30-2008, 04:17 PM
