72 four door's Avatar
clutch helper spring broke
On my 82 sc the omega helper spring[clutch] broke i see there no longer available any suggestions? do i need this piece?
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 05-31-2007, 04:32 AM
Friend of Warren
I would call PP and see if the older helper spring would work. They sure look the same in the pictures.
Kurt V
Old 05-31-2007, 06:14 AM
bigchillcar's Avatar
this probably doesn't help you, but the clutch return spring broke on my old '74 and i drove it for 5 years without ever replacing it. i'm guessing the big omega does a bit more that you need from it though.
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-31-2007, 09:25 AM
The clutch omega/helper spring broke on my 80 SC a couple of years ago > and I'm still driving it with broken spring.. no overt/readily noticeable ill-effects... I will replace it .. when I get around to it
kgl
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 05-31-2007, 11:46 AM
