-   -   passenger side window - slow (http://forums.pelicanparts.com/porsche-911-technical-forum/349374-passenger-side-window-slow.html)
mtelliott 05-30-2007 12:38 PM
Passenger side window always went up slow. Suggested that I install new felt in window track. Ordered felt from Pelican, installed, it now goes up slower. (When I had the felt out, it went up like normal)
Seems the window gets very tight towards the top of the track. Is there a way of trimming the felt to make it better or do I have something else going on?
Michael
fumanchu 05-30-2007 01:19 PM
suggestion-
The window frame may be installed at the improper angle. Mine does this too...., and judging by the wind noise on that side, the frame needs adjustment because there is a bind along the travel.
Rusty Heap 05-30-2007 01:22 PM
Try a little silicone spray on your felt.
mtelliott 05-30-2007 01:44 PM
Originally posted by fumanchu
suggestion-
How hard is it to adjust the frame. I've never looked at the adjustments on it.
rs6er 05-30-2007 04:00 PM
Just pull the plugs on the front and rear of the door and the attaching bolts will be exposed. Loosen them and shift the frame a bit.
BTW. When you put the new felts in, did you have to remove the inner door panel? I have one sitting around that I ordered, and have been curious how to install it.
mtelliott 05-30-2007 07:01 PM
Thanks for the info. Pulled the felt and put the new in without pulling the panel. It took some work to slide it down towards the end but it went. I used a little lubricant on the inside to help make it a little easier. I read a post by John Walker that explained it well. It was one of his first post on Pelican. He's always a wealth of info.
I'll be working on adjusting the window this weekend.
Michael
mack6820 05-31-2007 04:01 AM
Good post guys. I have the same problem with both my windows. Also the passenger side doesnt go down all the way. I'll have to check it out.
thanks!!
