-   -   Turn signal does not return to "off" (http://forums.pelicanparts.com/porsche-911-technical-forum/349620-turn-signal-does-not-return-off.html)
Curve Eater 05-31-2007 07:00 PM
Must be broken. The turn signal indicator used to turn itself off.
What is the fix, and if it is a part, which one? Any pics?
Regards,
Bill
widgeon13 05-31-2007 07:21 PM
It's a small circular part that has an ear that sticks out and hits the turn sign switch to turn it off (back to the mid position) mine broke and I found one on an old steering wheel, not sure where to buy one and never seen as an aftermarket piece. Perhaps Parts Heaven or dC Automotive. Someone may have one on the BB if you ask on the parts board. Good luck.
Curve Eater 05-31-2007 07:35 PM
Thanks, appreciate the feedback. So, anyone have an old steering wheel?
Bill
jazzbass 05-31-2007 10:23 PM
Yep, you probably need a new slip ring:
http://www.pelicanparts.com/cgi-bin/PartsLookup/search.cgi?command=show_page&Catalog_Name=911_USA_ 84_86_KATALOG&Illustration=403-05&Line_Item=36
P/N 911-347-099-05. $15 - not bad.
widgeon13 06-01-2007 03:33 AM
As mentioned, I was looking for one about ten years ago and didn't know PP had them, maybe didn't back then. Good to know info.
