MAGA
134 high/low AC pressures in stock system?
I misplaced my notes from when I initially converted my stock '79 SC with York from 12 to 134. DIY 134 conversion in SC complete!
After 2 years of service, it needs a boost of refrigerant (not bad for all original hoses and fittings other than a new drier). I hooked up the gages and had 70 psi system pressure, I fired it up and with the deck lid down and 80 degree ambient, I put in one can and ended up with about 15-20psi low side and 200psi high side. My vent temp is mid 40's and all seems well. I just can't find where I originally came up with the proper pressures for 134 in a SC. I think I may have had higher pressures originally. Anyone know the "recommended pressures" for a stock SC converted to 134?
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
MAGA
bump for the PM crowd.
You may be a bit low; but check with a thermometer at the dash air louver closest to the evaporator - add more refrigerant until the cool air temperature stops falling, then stop.
Engine deck lid down and engine running at 2000 rpm to pull air through deck lid condenser: For 134a, approximate values: Low side: 16 to 29 psi for 33 to 50 deg F evap temp 19 to 39 psi for 33 to 60 deg F evap temp 25 to 43 psi for 40 to 65 deg F evap temp 37 to 51 psi for 48 to 65 deg F evap temp High Side: 115 to 200 psi for 70 to 80 deg F ambient temp* 140 to 235 psi for 80 to 90 deg F ambient temp* 165 to 270 psi for 90 to 100 deg F ambient temp* 210 to 310 psi for 100 to 110 deg F ambient temp* *temperature of air moving over condenser usually measured two inches in "front" (front is side receiving air first) of condenser. If the pressures you measure are too high and you have air moving over the condenser(s) while you are measuring pressures then you will likely benefit from less refrigerant. |
MAGA
Thanks Jim, I will leave it at 200 high pressure for now as it seemed to be working well and by your numbers posted above, I am in the ball park. (I was indeed running at 2k with the deck lid down resting on my hoses and a fan blowing air at my left rear wheel well and the ambient temp was 80 and the AC evep blower fan was on high.)
I now know that I can always shoot a bit more in if it seems lacking on the highway once we have another real hot 90+ day.
Do you have the quick release service ports on yours? I tried adding them but my compressor fittings have larger threads on them. I can't seem to find them at the local parts stores. Do you know where I can buy them?
'86 911 Carrera coupe (silver) needs a lil' love ![]() '90 VW Corrado G60 (yellow) close to death ![]() '90 VW Passat wagon (white) a lot closer to death '97 Chevy Astrovan (moms car) POS died! ![]() '03 GMC Safari conversion van
MAGA
Works fine, but should I ever sell the car, I will want to put some proper adapter fittings on so the new owner can take it to an AC shop (I will probably die while owning this car however ).
just spent some time on our hosts site and didn't find anything to help me. My compressor looks as if the ports are permanently attached. That doesn't seem right!? It's getting hot here in Florida...
MAGA
MAGA
If your car is stock check this link out. http://www.griffiths.com/shop/index.php?main_page=product_info&cPath=15_16_17_70&products_id=93
