Tom '74 911's Avatar
Clutch cable compatibility
Hi -
I have a '74 915 trans. The clutch cable looks to be 6mm at the pedal end and 7mm at the trans end. The online catalog here says that cable is out of stock. Will the 6mm/6mm cable or the 6mm/8mm cable work for me? I'm assuming the 6mm/7mm cable for the Turbo won't work because the trans is different?
Thanks for the help,
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 06-03-2007, 03:05 PM
