Question Oil cooler scoop question
I'll be running in an autocross soon and was wondering if I should put in the oil cooler scoop I've had for the past year.
Does it really help even though I have a fan?
If I do put it on, will the increased flow cause excess wear on the fan by spinning it faster on the motor, or will it slow down the fan?
Brian
1989 Carrera 3.2 Silver Anniversary Edition
2007 BMW 750Li
2005 Honda Odyssey EX-L
http://forums.pelicanparts.com/porsche-911-technical-forum/285064-new-member-have-pics.html
Old 05-22-2007, 07:51 PM
2002M3Drew's Avatar
Send a message via AIM to 2002M3Drew
It really does nothing...kind of looks cool, but that's it. It simply does not allow enough airflow to +/- affect anything. It will not negatively affect your cooler or fan. (I do have one, by the way...)
1983 911SC Coupe
1985 928S
1987 944 Coupe
1992 Carrera C2 Coupe
2006 Cayenne S
Old 05-22-2007, 08:14 PM
drag racing the short bus
dd74's Avatar
Like Drew, I also have an oil cooler scoop. Unlike Drew, the scoop lowered my temperatures about 10 to 15 degrees.
The Terror of Tiny Town
Old 05-22-2007, 09:06 PM
I have two oil cooler scoops. One on each side.
I've recentely added a 2nd Carrera cooler to the other side of the car (drives side).
I'm not sure if they make a difference or not (since I've not had a chance to test it), but the visual effect is great. My car now has "horns" (like a bull).
TonyG
LSx 951 with 997 Cup Suspension - vision944.tonygarcia.org
3.6L 911SC - www.tonygarcia.org/911SC
Old 05-22-2007, 09:52 PM
Large Registered Member
PatrickB's Avatar
I have one too...
I can't believe it would make much difference at lower speeds on an AutoX run... High constant speed it helps. DE's At Big Willow, I've not seen oil temp rise above 200.
At constant cruising speed, it makes a remarkable difference! At high outside temps, high cruise speed with A/C on, I've seen 25-30 degree lower temps with the scoop!
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 05-22-2007, 10:03 PM
Thanks for the replies.
Sounds like it works better on the Interstate than in an autocross.
I won't worry about it for now; it I have time, I'll put it on. If not, the car should be okay.
I agree; I think it looks cool though!
2007 BMW 750Li
http://forums.pelicanparts.com/showthread.php?s=&threadid=285064
Old 05-22-2007, 10:42 PM
cycling has-been
bkreigsr's Avatar
plus, if you are running a stock ax class, the scoop could be cause for a protest. (non-factory cooling aid)
Bill K
Old 05-23-2007, 04:39 AM
81 911 SC's Avatar
I have the scoop and have noticed on highway driving etc my temps do not get above 180 where as before they would on hot days occasionally. I would say it does do something but it is only effective when the car is in motion. I also have upgraded to a carerra oil cooler up front.
- Tyler
1988 911 Carrera Grand Prix White/Black
2015 Cayenne Diesel Black/ Luxor Beige/Black
Old 05-23-2007, 04:53 AM
Porsche virgin's Avatar
Note that your '89 has a cutout under the front bumper above the passenger's fog light that already allows air to get to your cooler at highway speeds. Accordingly, you may not see the cooling gains that people with earlier cars (pre-'84) have.
Your Carrera cooler and fan is plenty sufficient for an autox.
'08 RX350 (Hers)
'84 911 Carrera
'83 911SC Cabrio
'06 Miata
Old 05-23-2007, 06:42 AM
Priced-out of Porsches.
mmastro's Avatar
I have one too, and have not seen oil temps above 210 even during the hottest days at Streets or Big Willow (but I DID install a center B&B oil cooler in series w/ my Carrera cooler).
If worst comes to worst, could you remove your right front turn signal assembly for more airflow to your Carrera cooler?
Mike
SoCal
Old 05-23-2007, 07:04 AM
I've looked and I don't see any cut-out as depicted in Wayne's 101 Projects book. There is only a 1cm gap that is in between the bumper and front valance. No obvious cutout.
Bill, it doesn't really matter to me if there is protest. I go to AXs for improving my driving skills and to get to know my car better. But I appreciate to heads up!
Brian
2007 BMW 750Li
Old 05-23-2007, 08:16 AM
cycling has-been
bkreigsr's Avatar
I'm with you Brian,
btw I have one and like the west coast trackies, my oil temps stayed 180-190 at Watking Glen in the summer.
before install 250-290 was not uncommon, (also got rid of thermal reactors)
Bill K
Old 05-23-2007, 08:52 AM
I wonder if they got rid of the cutout when they switched from the 28 tube brass cooler to the Carrera cooler with a fan...interesting.
'08 RX350 (Hers)
'84 911 Carrera
'83 911SC Cabrio
'06 Miata
Old 05-23-2007, 09:08 AM
I don't think so, my car has the cut out, just an FYI
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 05-23-2007, 09:47 AM
Not the best shot, but it does show it a little bit......
another
-Chris
1998 CR500
Old 05-23-2007, 09:52 AM
I just love this thread
Jerry
JMPRODUCT DESIGN
Old 05-23-2007, 09:59 AM
goober's Avatar
I designed this one up with my race logo on it "Speed Dog" and SLA'd a prototype. I saw the temps drop by ~15 degrees while on track.
Old 05-23-2007, 12:41 PM
Goober
I'm sure you will adhere to the 20% license fee for any scoops you sell.
Jerry
Old 05-23-2007, 01:15 PM
PatrickB's Avatar
Originally posted by JMPRO
Goober
Jerry
Go Get 'em Jerry!
Old 05-23-2007, 01:16 PM
If you really want to improve oil cooling go with a front valance cooler.
Old 05-23-2007, 03:51 PM
