Semper drive!
rcecale's Avatar
Ignition Switch Wires
I'm trying to wire my Valentine-1 into the existing wiring on my 86. The instructions that came with the V-1 say to connect to a wire that has power while the ignition is turned on. Okay easy enough, right?
Well, looking through the schematic in the workshop manual, it clearly indicates there should be a green wire coming from the ignition switch which ultimately gets to the radio. Perfect, this is a system that only has power when the ignition switch is turned on. all I need to do is look up under the dash and find the green wire coming out of the ignition switch, trace it along to a convenient location to attach to and proceed as the V-1 manual states, right? Well, I've problems.
Looking at the ignition switch, all I can see are a collection of various RED wires, a YELLOW wire or two and that's about it. A few RED wires have different colored stripes, but none of them are green.
How do I determine which wire to connect to, short of trial and error?
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 06-04-2007, 03:34 PM
A voltmeter or circuit tester would be helpful for what you want to do. Probe the back of the ignition switch for a terminal that has source voltage when the key is in the ON position. Install a piggyback spade connector to splice into this circuit to provide source voltage to your radar detector. Alternately, find a similar circuit at the fuse box.
In all cases, verify your add-on circuit is protected by a fuse of the correct rating.
Hope this helps,
Sherwood
Old 06-04-2007, 05:26 PM
Semper drive!
rcecale's Avatar
Thanks, Sherwood! Ended up doing pretty much that exact thing. Got it all hooked up and working now.
Randy
One Marine's View
Old 06-05-2007, 02:19 AM
