-   -   Installing 993 heat exchangers (http://forums.pelicanparts.com/porsche-911-technical-forum/350268-installing-993-heat-exchangers.html)
WydRyd 06-04-2007 04:13 PM
Curious, once the flanges on a 993 heat exchanger is clocked to fit the earlier motors, is a special tool required to access the nuts to install them?
Is such a tool available off the shelf, or is a custom solution needed?
Zeke 06-04-2007 04:21 PM
I don't know about the tool, but I'd love to see your setup.
PcarPhil 06-04-2007 04:46 PM
http://forums.pelicanparts.com/showthread.php?s=&threadid=257293&perpage=20&highl ight=flowmaster%20muffler&pagenumber=5
JP911 06-04-2007 05:24 PM
It's a pain in the a$$. I cut an offset box wrench, tried a socket on a magnet, yelled at it, etc. This combination eventually got me there...although the yelling didn't seem to do much.
RarlyL8 06-04-2007 07:31 PM
Here is a pic of the 993tt HEs stock and clocked. You can see that one side is now not aligned with the access holes.
http://forums.pelicanparts.com/uploa...1181010601.jpg
http://forums.pelicanparts.com/uploa...1181010639.jpg
klaucke 06-04-2007 09:01 PM
http://forums.pelicanparts.com/showthread.php?s=&threadid=249471&perpage=20&pagen umber=5
WydRyd 06-04-2007 09:01 PM
Hmmm... looks like it'll be a major PITA and I'm going to have to install these with the motor still in the car as I don't have a garage ready yet :mad:
Can anyone here make me this wrench? My fabrication facility is quite limited ;)
Kevin Stewart 06-04-2007 09:31 PM
dont have the wrench but have a jig to clock the 993 heat exchangers
Rouxzy 06-04-2007 09:59 PM
Kevin does in fact have the jig that works quite nicely. In fact he let me borrow it when I had mine done. Thanks again Kevin.
Tom
JP911 06-04-2007 10:45 PM
Merv-
Don't be discouraged. It's not impossible, just one of those things that requires ALOT of patience. The design of the Snapon wrench that Tyson used in the post klauke linked to is available from numerous manufacturers.
WydRyd 06-04-2007 11:15 PM
Thanks - what's that type of Snapon tool actually called? Is there a special name for it? I just want to know what I'm asking for when I call around SmileWavy
Flex-head with open end maybe?
What about something like this?
OR this might be better?
