Having problems torquing the Elephant Racing front monoball.
I am installing the ER front monoballs, and can not gat any tool to hold the bottom whilst I torque the top. The camber plate is shaped in such a way that there is not enough for me to grab on the bottom part of the monoball. I have tightened it up as much as I can, but now it just spins and is not tightened to the specified torque setting.
Any advice on how to keep the bottom part from spinning would be greatly appreciated - I will assume that using the monoballs when not torqued to the correct setting is a BAD idea!! |
I use a big pair of channel locks to grip the bottom. Takes two people, one to hold the channels locks another to tighten the top. :)
Thank you for the reply Chuck - bad question, but what are channel locks?
I will have to go to the local tool shop and see if i can get one... |
Thank you scottb - that is what I am using, but I can not get a good grip. I will have to go and get a smaller pair, maybe the one I am using is to big.
http://forums.pelicanparts.com/uploa...1181071419.jpg |
We also call them slip-joint pliers,.......:)
monoball socket size
what are you using to tighten the top nut ? I wanted to buy a socket for this so I dont scratch/chew it up.But I am getting 47.5mm with my caliper gauge.anyone know the size and recommended torque ?
nevermind
nevermind guys,I got it.1 7/8 socket and 60 ft lbs.
| All times are GMT -8. The time now is 01:49 PM. |
