Tom '74 911's Avatar
11mm Fuel hose?
Good day -
I'm revamping my fuel system and am curious as to where others are sourceing larger diameter fuel line/hose like the 11mm ID section from the tank to the fuel pump? Pelican has it listed, however it has a "ships in 3 days" note along with the statement that it may have to be sourced from Germany. I've done some searching and haven't been able to find it elsewhere. Can someone help?
Thanks,
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 06-03-2007, 06:23 AM
304065's Avatar
Search here under the word "Cohline"
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-03-2007, 06:27 AM
BoxsterGT's Avatar
This fuel hose is available in plain rubber and also in Zinc braid. It has an 11mm id and a 16mm od.
Most places don't stock it as there is very little demand.
I carry the plain rubber, braided zinc, and braided SS in the common 9mm id.
I have been making up various Porsche fuel & oil hose assys for many years, and this is the first request I have heard for this size.
If any questions, please email me as my PM box seems to be stuck in the full position.
Len@autosportengineering.com
Old 06-05-2007, 10:30 AM
Len -
Thanks for the response. My car is a '74 911. Originally, the fuel pump was in the back, by the DS rear swaybar mount. Due to the vapor lock situation, a previous owner moved it to the front. As a result, there's a bit of a mismash of hose, reducers/enlargers etc.... Really the best thing for me to do would be to replace everything w/one hose - including the plastic line through the tunnel. I'm not sure I'm up for that though at the moment.
The original parts diagram called for 11/17.5 fuel line as a supply to the rear mounted pump - see here #9. I still need a similarly sized line from the fuel tank to the fuel pump (in it's new location).
When possible and w/in reason, I like to use parts that fit correctly - although I try not to be too crazy about it. I talked to the previous owner who's an independant porsche mechanic and he said when he did the fuel pump relocation, he used some non-metric hose from NAPA. I just got some 1/2" ID that I'm going to try.
I tend to make things more difficult than they need to be sometimes. It's a hard balance between what is called for in the parts diagrams, what's readily available and what will really work in the end!
Thanks,
Tom
Old 06-05-2007, 11:23 AM
1/2" fuel injection hose (from NAPA) worked fine for this application on my 74. I'm a little paranoid when it comes to making changes to the fuel system so I check often for leaks. It's been about 1,000 miles (including track days) since the change and no leaks.
Old 06-05-2007, 11:33 AM
Thanks for the reassurance Jon!
Tom
Old 06-05-2007, 11:42 AM
BoxsterGT's Avatar
This looks like the suction side of the pump, and is very low pressure.
It should not be a problem using US fuel injection hose & the good Norma hose clamps.
As a side note, thirty plus years ago, fuel & oil hoses were made using pretty much the same rubber compunds.
Today this is no longer the case.
Hose mfgrs have had to develop what some describe as "Super Fuel Injection" hose, using compounds made to withstand the effects of a high alcohol content now in our fuel nationwide.
It is highly recommended that anytime someone replaces the fuel hose on their Porsche, even when using a Carburetor system, they use the highest quality fuel hose available.
Cheers,
Len
Old 06-05-2007, 12:49 PM
barney911rs's Avatar
Len,
Those are nice looking lines.
As for the NAPA stuff, the hose itself should not be of any concern, it's just a matter of making sure the connections are all tight and secure. I'm not using anything stock, so I can't attest to anything on that side. I can appreciate wanting the correct parts for a street car. Good luck guys.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 06-05-2007, 01:27 PM
Bollweevil
Re: 11mm Fuel hose?
Originally posted by Tom '74 911
Good day -
Thanks,
Tom
I recently replaced the fuel line in question (part # 9) that goes from the plastic line exiting the tunnel the the fuel pump on my '74.
I used 10mm ID line which fit perfectly but was very difficult to find. I tried 3/8" which is 9.5MM and it was just to small and 1/2" which is about 12.5MM was just to large. Per my caliper measurement, 10 MM was the size needed.
I could find no place on the internet where I could order it in small amounts. When I called Pelican I was told they didn't carry it ??
A local foreign repair shop was able to order a 3' piece of the German hose @ $5 / foot which was outrageous but little choice.
None of the local European car dealers even carried metric sized fuel lines.
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 06-05-2007, 02:33 PM
The PMO carb kit comes with metric fuel hose with BMW stamped on the side. Maybe try a BMW dealer?
Old 06-05-2007, 02:35 PM
