no reversing lights???????
Hi , my reversing lights aren't working the fuse and bulbs are both ok!
any ideas anyone please |
Check that the wires are properly connected tot he switch on the nose of the transmission. If they are you will need to start checking continuituy on the switchand the wiring.
That's the switch, Dan.
It is a simple contact switch but it is a pain to replace. The tranny has to be lowered to get it out. It should be easy to check the functioning of the switch while it is still in place. |
| All times are GMT -8. The time now is 08:25 PM. |
