Oil Change and now change?
I did my own oil change a week ago, while I was changing the oil and filling it up I could hear a harmonic sound. It went away when I put another quart of oil. Talked to my mechanic about after I went to see him to check the exhaust emissions where in check. He didn't know what it could be.
Well yesterday after leaving work I heard it again. And today again....it seems to happen only on start up and then goes away on warm up...its like a metalic, harmonic sound ...everything on the car feels fine, druck is normal and no back fires... 20/50 weight on the oil due the Az heat
Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 |
Immature Member
I noticed a sound from my oil tank last year, but I wouldn't describe it as metallic. When I switched to 15w40 I would hear a 'burbling' sound when i first started it up. I believe what I was hearing was oil that had settled into the crankcase being pumped up into the tank. It would go away after about 30 secs or so. I don't notice it so much with the 20w50 oil, but the mornings are still pretty cold up here.
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
Now with Video and Sound
You hear the sound between 6 seconds through 10 seconds What is this sound????? Last edited by FenderGuy; 06-18-2007 at 06:29 AM.. |
I have never heard a Porsche engine sound like that
Just kidding. What I wanted to saty is the sound quality of your video is simply not able to reproduce the engine sound for any remote diagnosis. Other than telling that it runs..... If you are really concerned I would take it to an experienced shop/mechanic to listen to it. Don't take chances. Did you change to a different oil weight or type?Weired sounds can come from a lot of different things. Poor valve adjustment on one or more valves, oil starvation in the valve train, a bad bearing, rod knock, piston slap, etc. Good luck, Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
what part of the engine does the sound come from?
I can't hear any thing odd in the movies.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Large Registered Member
To me, it sounds more like a whine from the alternator.
Usually mine would make the same sound on start up, but go away a few minutes after the engine warmed up... I actually just replaced my alternator 200 miles ago, and no more weird noise! My alternator was actually starting to show signs of failure after 22 years, and 158k miles... I didn't want to wait until complete failure left me stranded somewhere, so I replaced it... Just for clarification, my alternator has made that funny bearing noise for the last 5 years until warmed up...
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
Ok got rid of one vid, you guys can't hear a weird sound at 6 to 10 seconds? It seems to come from the left side...someone suggested it was the alt pulley? My alternator was replaced when my old engine alt light was going out...
I know the sound of a piston letting go, which sucks but it does not sound like that...it comes around start up and goes away after warm up...
Sounds like alternator to me also....Try turning your lights, heater, a/c fresh air blower on all at the same time and see if the noise increases.
madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) |
If it is the Alt, I just had it replaced a few months ago...How can that be?
Purely an unedumacated guess on my part... Just throwing in my $.02 when I had what I though was a similar noise!
You can hear it better here So is this an Alt sound?
oh ya that's the alternator, mine is making the same noise. If you really want to be sure, pull the belt and fire it up for a few seconds. But I hear the sound and it sounds identical to mine (which I have not gotten around to pulling yet).
1974 911 targa 2.7 (for the road) 1974 FJ40 Landcruiser (for no roads) 1995 Dodge V-10 HD2500 4x4 (to tow anything I want) 2005 Durango (wifes rig, I've driven it twice) 2000 Fisher Freedom 200 w Mercury 115 ELPTO (because the world is mostly water) |
Giving Props to Don Jackon in Phoenix Az.
DJ said he would warrenty the Alt if it is bad, how great is that... Don Jackson rawks
