-   -   Engine sound pad question... which one to use? (http://forums.pelicanparts.com/porsche-911-technical-forum/350978-engine-sound-pad-question-one-use.html)
defcon65 06-11-2007 12:52 PM
Didn't know, thanks for the heads up. Isn't there a peel and stick neoprene material used for the same effect? That's what I'm looking for. I saw it used to line an inboard boat engine compartment, and I've seen similar stuff in car audio installs. It's about 3/8" thick, very dense with adhesive on the back.
I don't mind the engine sound so much, but the adhesive residue looks like rust and I want to clean up the engine compartment.
randywebb 06-11-2007 01:36 PM
They make something for underhood use - it might be ok on the motor side of the firewall. Likely heavier than the stock pad tho.
One thing is you sure can't beat that price.
I am wondering what makes him say the product is the best one made - do you know? Or is it just 'company pride?
911pcars 06-11-2007 03:24 PM
"He says it's the best sound deadening material out there."
Could be, for audio purposes, but it's heavier than some alternate materials. There are other sources for basically the same material, but w/o the Dynamat trade name attached (makes it pricier).
Sherwood
gsmith660 07-26-2007 01:22 PM
http://forums.pelicanparts.com/uploa...1185481213.jpg
I am doing a complete restore so I am going to put my sound mat on the other side of the sheet metal and leave this nice looking paint
Poohsan 07-26-2007 05:10 PM
That looks KILLER!
JeremyD 07-26-2007 06:18 PM
I have the bling bling Yo Boy foil backed - trimmed appbiz aftermarket sound pad - it's light - it deadens the sound on par with the factory pad, it doesn't fall apart, and I have seen no difference in engine temps even running a larger displacment, hotter cams and higher compression http://forums.pelicanparts.com/uploa...1185498937.jpg
911 in SC 07-26-2007 06:24 PM
Jeremy, did you buy the sound pad with the perimeter binding or without? How's the heat inside the car? Any different?
Thanks,
Mike
JeremyD 07-26-2007 07:18 PM
With binding - no difference in heat or sound
911 in SC 07-26-2007 07:29 PM
Sorry for all of the questions BUT did you try it without either sound pad? I don't have a pad now, and the rear seats do get a little warm. I'd like to keep the temps down, as my 7 yr. old daughter doesn't complain, but I want to keep her as comfortable as possible. If the pad will reduce temps inside, it's well worth it. If not, I'll keep my car the way it is (it sounds great!).
Thanks,
RWebb 07-26-2007 08:52 PM
Once heat or noise 'hits' the sheet metal it is much harder to deal with. The sound pad on the engine side is going to be much more effective at both heat & noise control.
OTOH, that bare but finished texture does look good - so if you have carbs or something that let's you see the firewall, then you have to balance the visual w/ the heat/noise issues.
I prefer the Al foil type pads if you want that maximum "Roasted Chicken" bling effect.
911pcars 07-26-2007 09:08 PM
I installed some Mylar-backed, 1" foam material out of the JCWhitney catalog; created a pattern with paper, tape and scissors, then transferred onto the material. Added Mylar tape to cover the cut edges. I believed I used contact cement on the bulkhead as well as the foam.
Since my car was out of commission for years when I did this, I can't speak for the sound or heat reduction of such a pad. As a wag, i'd say it reflects some heat and reduces some sound.
2-year old photo:
http://forums.pelicanparts.com/uploa...1185509178.jpg
Sherwood
JeremyD 07-27-2007 06:02 AM
Ha Ha - knew Randy would chime in - Do you think that's why I am getting all this HP? Maybe the foil backing is focusing the power waves from the flux capacitor...
JBO 07-27-2007 06:17 AM
I used the same stuff Sherwood used, but I got it at Pep Boys. I wasn't concerned about the sound, and was mainly concerned about a hotter passenger compartment with no pad. It has been in place a few years now and seems to work well.
gsmith660 07-27-2007 07:54 AM
Im going on the same principle that you put dynamat on the inside fo your doors to stabilize the metal and on the outside of the inner door panel to cut vibration from the stereo resonance
RWebb 07-27-2007 08:12 AM
regular Dynamat works primarily by making the panel heavier
a heavier panel has a resonant frequency that is lower than a lighter panel; the peak amplitude ("Q") is also reduced
an analogy is sticking wad of asphalt on a kid's drum head - the metal panel is exactly like the drum head (since drummers tend to have strong forearms, this experiment is best carried out using a young kid)
gsmith660 07-27-2007 10:42 AM
I always thought that it was kind of like the the radar absorbant material on planes it would slow down the wave as ait traveled thru the material until the amplitude dropped off to 0
911pcars 07-27-2007 11:36 AM
Just to add another theory;
I thought the added material changes the vibration frequency of the base material.
Quick. Someone call JCWhitney tech support for the answer. :)
Sherwood
RWebb 07-27-2007 02:21 PM
"changes the vibration frequency of the base material."
- isn't that what I said??
911pcars 07-27-2007 02:38 PM
Randy,
Yeah, but I wanted to say it too. :)
Sherwood
gtc 07-27-2007 02:57 PM
After reading this thread this morning I went out at lunch and pulled out my old, falling off and apart factory pad, then went for a drive. There wasn't any appreciable difference in sound levels.
